Question about Sewing Machines
The bobbin thread stitch is loose even after
My newly adopted rarely used (three times maybe?) Singer Sewing machine circa 1979 has made it through one project but now is giving me problems with the bobbin thread. It still remains loose even after adjusting the tension dials re-winding the bobbins and using different bobbins altogether. Should I be worried this is a big problem or is it something that can probably be solved by a cleaning and tune-up?
    Problem Solver:
  • 13 Answers
Is the bobbin in backwards? mine comes off the bobbin counter clockwise. I'm not sure if they all do or not
Posted on May 14, 2010
Purchased singer 6233. Filled bobbin and thought it was installed properly, but stitching just comes out by pulling on thread.
Most likely a tension problem. Tighten the upper thread tension. If the top and bobbin threads are not interlocking, then the machine is out of time. Search for sewing machine timing or take it for service.
Feb 27, 2017 | Singer Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
I have an old singer sewing machine circa 1979, and I'm having problems with the bobbin thread not being picked up by the needle
your needle may be in wrong make sure flat side of needle is at the back of the holder.If that is not helping it needs some timing work on it.
Aug 18, 2010 | Singer 3116 Simple
Set the tension back to the recommended setting for the type of sewing you are doing.
Lift the presser foot. Rethread the machine. Always thread a sewing machine with the presser foot up as this opens the tension control and allows the thread to "seat".
What looks like the bobbin thread is mis-stitching is actually the top thread not holding the stitch due to the tension control not having control.
Cleaning and a tune-up is always a good idea when there is heavy use or the machine has not been used for a long time.
The bench charge starts at about $80 plus any parts that need replacing.
Mar 20, 2010 | Sewing Machines
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Apr 23, 2009 | Singer 7442 Mechanical Sewing Machine
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Singer 626 Not sewing
First, give Mom all your Reese's Peanut Butter Cups.
Then, be sure the bobbin-winding function is not still engaged. Check it again, since on some machines, the mechanism has to be backed off until you hear a click, or until a light turns off. If that's done, check the tension on your top thread, since that's easier, then on your bobbin thread.
If the bobbin didn't get wound evenly (Like if you're hurrying) that will mess up its ability to let the thread flow out, so see if the thread on the bobbin looks as smooth as a new spool of thread.
I hope you got your costume together & had fun aside for that frustration. :^)
Oct 29, 2008 | Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
