Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
The upper spray arm came off. How to I put it back on?
The upper arm of my Frigidaire Professional Series dishwasher came off.  I don't know how.  The are doesn't look like anything is cracked or broken.  When I try to push it back in place, the receiving swivel recedes into the dishwasher roof.  Any idea how to put the arm back on?  I appreciate the help.
  • 2 more comments
  • plt311 Mar 30, 2008
    yes, i have the same problem.. the screw on part is not the problem. it is the white plastic snap-on thing that holds the spary arm comes off easily. Do i need to order a whole new spray arm??
  • Anonymous Apr 10, 2009
    Had same problem. Unscrewed and snapped rotating arm back on. Originally looked like a piece was missing, I guess its designed to snap off rather than break.
  • Anonymous Apr 20, 2009
    thanks to love_2bhate - just did as he said. Even with my handymen's ability (0) it was easy. Took me a while to put a round piece back, but it is me ;-))
  • Anonymous Mar 25, 2014
    upper spray arm fell off how do I get back on
I realize this problem was in March of 2008 but if in the case someone else needs the solution. The Frigidaire website doesn't list this in there troubleshooting list either.
I had the same problem and let the upper spray arm off for a couple of months. My glasses were not getting cleaned as well so I was rewashing everything by hand. What's the point of that if I have a dishwasher.
On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
From now on be careful what you place on the top rack, if the item is too big it will cause it to snap off again. I know I will :)
Thank god I didn't get a repair man in here for something as minimal as that.
Posted on Nov 27, 2008
Yes, my husband just unscrewed the round piece on the upper top of the dishwasher that the arm attaches to and problem solved
Posted on May 06, 2009
    President:
  • Frigidaire Master
  • 2,651 Answers
The upper most spray arm simply scrws into place onto the spray arm manifold, you shouldnt have to , but if needed you can oull unit out from under counter and hold pressure down o nthe manifold as you try to crew on from underneath, part number 154478201 if you need to replace the spray arm
Posted on Mar 30, 2008
Yay!!!!!! This solved my problem. Who knew it screwed off! Thank God for internet! Thanks!!!!
Posted on Aug 09, 2012
Thanks
I want you all to know that I pulled the round piece off - it would not unscrew, but did screw it back into place.
Posted on Jul 15, 2009
2 Suggested Answers
SOURCE: upper spray arm broke off
I hope it did not break, only came off. I had the same problem. You have to unscrew the round part from the ceiling of the dishwasher, put the three pieces together, easy, and then screw the whole thing back. No tools needed. Top rack can stay on while working. It helps if the dishwasher is empty. If the threading is good, this should solve the problem.
Posted on Apr 16, 2009
Grinding during wash cycle
Possible that there is fault in the spraying unit or arm. It can also be due to faulty PUMP or a dirty filter which can CHOKE the pump.
remove and clean the pump and filter
check this link for tips : spraying arm
Jan 11, 2013 | Frigidaire Professional Series 24 in....
Spray arm comes out during cycle
See if there are any plastic pieces broken or cracked on either part of the sprayer arm, then contact Frigidaire.
Aug 12, 2012 | Frigidaire Professional Series 24 in....
I have a Frigidaire dishwasher model # GLD3450RDS0 and the upper spray arm has come off. I have the arm but it will not go back in place. Am I missing a washer or something to secure the arm? how do I...
You will need to get replacment parts...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 16, 2011 | Frigidaire Professional Series 24 in....
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
Upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Feb 04, 2010 | Frigidaire Professional Series 24 in....
The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
Upper spray arm broke off
Mar 06, 2009 | Frigidaire Professional Series 24 in....
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
2,887 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
