Question about Panasonic Viera TH-50PZ80U Plasma TV
Tv will not turn on. Flashes 10 times. If we unplug/plug it basck in several times we can eventualy get it to work. Seems to be getting worse every day.
    Guru:
  • 416 Answers
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
Posted on May 14, 2010
I called Panasonic Plasma Concierge. The first thing she asked about was whether there were any components attached by HDMI. I said, two a BluRay player and an Apple TV. She said that HDMI devices can lose sync and confuse the TV. Unplugging the TV for a few minutes and disconnecting the HDMI cables can reset everything.
She took me through the following process:
  1. I unplugged the TV.
  2. I unplugged both HDMI cables.
  3. I unplugged the two devices connected with HDMI.
  4. I plugged the TV directly into the wall.
  5. I turned on the TV.
  6. It worked.
She then instructed me to power up the HDMI devices and connect the HDMI cables. The BluRay player started displaying.
Problem solved. Don't go replacing anything until you try this.
Posted on Nov 07, 2010
Can the power supply for the TH-50PZ80U be replaced by anyone or does it require a TV Tech?
Posted on Jul 13, 2010
Turns off automatically and flashes 10 times
As far as I am able to see the model here does not have a 10 code, is it possible the wrong brand and model are listed here?
Dec 21, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Tv flashes on and off
If it is 10 to 15 years old, the CRT is weak or failing. A qualified technician may be able to improve the CRT, but it usually only lasts several months. Probably time for a new TV.
Sep 09, 2009 | Sony Televison & Video
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Panasonic Viera TH-50PZ80U Plasma TV Logo
1,707 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
