Question about U-Line Icemaker
I need the 3 rpm motor assy. for my marine ice maker model bcm45a
Cant find part any place
    Problem Solver:
  • 5 Answers
I think that's a .3 rpm (1/3 rpm)
Posted on May 15, 2008
My uline BCM45A ice maker is cold but does not make ice
This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
Sep 15, 2009 | U-Line Icemaker
Not sure of u-line ice maker part number for a BCM45A
Supco makes a generic replacement carried by most good Appliance Parts Stores.
Apr 04, 2009 | U-Line Icemaker
Kenmore Coldspot Ice Maker Gear Broken
best bet os to order and replace the entire assy, the gear broke due to an over torquing problem that they fix with a kit that ioncludes a new module and a new stripper bar, the labor involved and chance of breakin more parts make the entire assy a more feasable way to go, you can proble find a repacemnt online for undder $75
Feb 12, 2009 | Whirlpool ED2FHEXN Side by Side...
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Ice maker making ice with black specs in the cubes
youlkl need to replace the ice amker assy, the finish on the mould assy is coming off. only solution is repalce the entiire ice amker asssy
Nov 06, 2008 | Refrigerators
Icemaker won't fill
its a tricky one to diag, this IDI{in door ice maker}. id be interested to see something in the ice maker head assy itself, under the right side bottom of the ice maker asssy is a 1/4in screw, holding a cover for the wire harness,if you remove the screw and the plastice cover it will allow you to slide the ice maker assy foward, youll need to depress a small plastic tab on the left side wall preventing the ice maker from coming out any more than an inch or so. After that the ice maker will twist out and by inserting a screwdriver into ice maker cover you be able to "pop" off the front white cover to reveal the inner workings. a problem with some of their modules is that the center white gear actually cracks off the module head itself, if thats the case when you open the cover, youll need to replace the ice maker assy
Oct 25, 2008 | Refrigerators
Ice maker is not ejecting the ice cubes
sounds like you have an issue withthe ice maker mold heater, not afield servicable part, replace the entire ice maker a assy, easy to do 2-3 screws and a wire harness
Oct 24, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
BCM45A
unplug and remove 4 screws from front of cover and see if the cam is not broken. every time it dumps ice this cam raises the bar to shut off ice making if the bin is full. may be it just slipped?
Sep 26, 2008 | U-Line Icemaker
Ice Maker Not Making Ice
Great job! The motor module is bad, there were quite a few defective ones but the new ones have different colored writing on them ( I think Blue vice red). A new module is cheaper at Partselect.com, it's where I get my stuff from. The new modules should last about 7 to 10 years.
Apr 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
U-Line Icemaker Logo
116 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
