Sundenly I can't see my iomega External Drive 1.5 tb when I click my computer?
    Genius:
  • 1,189 Answers
Hi, click to open the Computer Properties, by clicking on the computer if on your "Desktop" or click on the "Start Button, in the (right pane) select to open the computer. Check to see if there's a DVD RW Drive (D:) in the "Device with Removable Storage area." If the area is (Blank)? Go to and select All Programs, after clicking on the Start Button; scroll to find the Media Disk Player. You made need to (Setup) your player, just open the Player and select to "Setup / Install, follow all the instructions, remember to click on the Apply and OK buttons when finished, and lastly, restart the computer. "Rating the solution for its helpfulness is appreciated, thanks."
Posted on May 14, 2010
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
Oct 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
My iomega hard drive worked fine before, but now won't show on My Computer or Autoplay. Help, please?!
First check whether your computer can see the external drive:
1. Right click My Computer and select Properties
2. Click on Device Manager
3. Expand Disk Drives by clicking the arrow on the left side of it.
Is the IOmega in the list of the disk drives?
If it is, then it is either:
1. The drive is faulty and the ID is from the IOmega controller
2. The drive is ok but severe bad sectors or other failing components prevent the drive to mount.
Testing the External Drive.
Listen closely to the if it sounds like it's spinning or it's doing something.
1. Clicking sound - The hard drive inside the Iomega caddy is faulty, either the pcb or heads, or both
2. Scraping sound - There is a platter damage on the drive. Recovery not possible.
3. No sound at all - Problem with either drive's pcb or the Iomega controller.
If your drive behaves like one above, I suggest you send your hard drive to data recovery companies.
May 06, 2011 | Iomega Professional 500 GB FireWire 400...
Hey i brought a iomega select desktop 1.5 tb hard Problem with the Iomega 1.5TB Desktop USB Hard Drive hey i brought a iomega select desktop 1.5 tb hard drive from argos got home and transferd all info...
  • Plug your Iomega hard drive into one of your computer's USB port.
  • 2
    Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key.
  • 3
    Go down to the bottom of the device manager to the "Universal Serial Bus Controller."
  • 4
    Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button.
  • 5
    Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive.
  • Mar 10, 2011 | Iomega 1.5TB Desktop USB Hard Drive
    Win 98 Drivers for Iomega Prestige 1 Tb external drive
    Windows 98 does not have an USB driver, You may get one from the Iomega WEB site for this external hard drive.
    Feb 05, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
    I have an Iomega Prestige 500 GB hard drive and its broken all it does is click click click and my computer doesnt recognize it..its still on warranty any ideas
    Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
    Jun 22, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
    Iomega 320 external hard drive computer wont recognise
    Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
    Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
    Could not find pretige iomega icon on my computer
    format the harddrive as MS-Dos to be able to use it on Mac and PC.
    Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
    Computers & Internet Logo
    115 people viewed this question
    David Payne
    David Payne
