Question about Bulldog Remote Starter & T-Harness Kit for 95-99 Nissan 200SX/Altima/Sentra
Why my coil ignition fusible blown at each time i change it? thanks the car is nissan sentra 2002.
  • 344 Answers
Your blue/black tack wire might be grounding through the firewall
Posted on May 26, 2010
Why does it lack spark?
Part 1 -How to Test the Ignition COP Coils (Nissan 1.8L)
troubleshootmyvehicle.com > Nissan > 1.8L
Feb 12, 2013 - What Tools Do I Need to Test the COP Coils. ... coils (most commonly known as the COP ignition coils), on your 1.8L Nissan Sentra is pretty easy. ... When one COP ignition coil fails... that cylinder goes 'dead' due to a lack of Spark and is said to be misfiring. .... 2000, 2001, 2002, 2003, 2004, 2005, 2006 ...
Part 2 -How to Troubleshoot a No Start (Nissan 1.8L)
Jan 17, 2013 - Checking for Spark With a Spark Tester. ... Your 1.8L Nissan will either have a distributor-type ignition system or the more modern COP ... A BAD fuel pumpwill cause your 1.8L Nissan Sentra to Crank but Not Start... since the ... Still, the other method that I've used to test for a lack of fuel... is spraying starting ...
2002 Sentra 1.8, no spark, code 0505... - Nissan Sentra Forum ...
www.b15sentra.net > ... > Technical Discussion
Nov 4, 2008 - 15 posts - ‎3 authors
I have never had a problem with the car before (02 Sentra 1.8/auto), so I had no need to post ... Originally Posted by Black B15 ... Join Date: Jun 2005 ... Can you see if the coilpacks are getting spark & work back from there? how many spark plugs do i need ? - Nissan Sentra ...
Mar 19, 2010
Spark Plug Replacement - 2002 GXE 1.8L - Nissan ...
Oct 12, 2009
1.8s starting problems - Nissan Sentra Forum - B15 ...
Jun 23, 2009
No start on 1.8L 02 GXE - Nissan Sentra Forum - B15 ...
Apr 11, 2009
More results from www.b15sentra.net
Jan 01, 2016 | 2005 Nissan Sentra 1.8
No spark on 2002 sentra se-r replaced crankshaft sensor and camshaft sensor.
heres a list, ignition components damp or damaged, worn or faulty spark plugs, broken...loose....or disconnectedwiring in starting circuit, loose distributor changing ignition timing, ignition coil loose...faulty or disconnected wires. its good your cam & crank sensors were changed, but no spark indicates coil packs not able to get spark to plugs, but spark plugs may be fouled, replace them. replace distributor cap & rotor. check fuses, there's one for the ignition switch, check it. try all this see how it does,, also, if you haven't replaced both the AIR & FUEL FILTERS , DO SO !!!!!!!! just for thought, my daughter has a sentra gxe,2002, it started losing power on the highway, we had to have nissan replace it, $900 , you may have to deal with this, sell the car ! when you get it running, if you want. although , after we did repairs, tune-up, timing belt (not chain), etc., it runs like a top, she loves it ! good car if you ask me, just keep filters new, brakes good, it will go forever !
Mar 11, 2013 | 2002 Nissan Sentra
2002 nissan wont start
Please check the fuel pump and the spark intensity. It is important that the pump is calibrated to give the best pressure at all times. If the regular scheduled maintenance was done on the car then it will be a breakdown in the electrical section. Check the ECU, check the plugs and the HT coils and the wires . Check the ignition trigger and the timings.
Feb 15, 2011 | 2002 Nissan Sentra
2002 nissan sentra in disrepair
The problem is in the ignition control module. Check it and make sure it is getting power to the module.
Sep 17, 2009 | 2002 Nissan Sentra
How do you install ignition coils in a 2002 Nissan Sentra.
On the Sentra each sparkplug has it's own coil first you have to find out which one isn't working. Most are just held in place by a 8mm bolt so just carefully unplug the wire to the coil then remove the bolt, slowly twist the coil back and forth till it comes loose at the plug then pull it up. This is for the 1.8 liter the 2.5 could have the coils hidden under a cover but is still one coil for each plug.
Jul 15, 2009 | 2002 Nissan Sentra
Replace timng belt
well maybe there was some mis-communication there , nissan stopped using timing belts in sentra's and actually most all models in 2000 , maybe they were telling you that your serpentine belt needed changed ? but to answer your question , you do not have a timing belt in your 2002 nissan sentra . its a chain . thanks
J5
Jan 19, 2009 | 2002 Nissan Sentra
Bulldog Remote Starter & T-Harness Kit for 95-99 Nissan 200SX/Altima/Sentra Logo
139 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
