Question about Gateway FPD2185W 21 in. LCD Television
My monitor stopped working
I looked for anything bad on the board.... nothing...well...noticeable.
any advice?
  • griffith457 Dec 28, 2008
    I changed the time to 20 minutes for the monitor to shut down when not in use and no it will not come back on
    Problem Solver:
  • 6 Answers
Http://en.wikipedia.org/wiki/Capacitor_Plague
Posted on May 22, 2008
Laptopscreen not coming on lights and fan ok
When it is running if you hold a light up to the screen, can you see anything on the screen? What about if you connect another monitor to the computer does that work?
If you see something on the screen using a light, you have a bad inverter or back light.
If you see nothing on the screen and nothing on an external monitor, you have a bad motherboard.
If you see something on an external monitor but nothing on the laptop then you have a bad cable or display on the laptop.
Mar 09, 2014 | Computers & Internet
My key fob stopped working overnight x type jaguar 2002
pop open the key fob from the side and you will notice a watch battery inside the fob, replace it and make sure nothing came unsoldered from the board and that should fix the problem
Nov 23, 2011 | Cars & Trucks
Screen truns red to green to normal to red
Try it on another PC first, if it is still bad, read on.
When you have strange symptom like this, first thing to look for are the caps (bad caps with bulging tops) inside. Common problem with these Princeton and other brands as well as you can see in my pictures:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Post back what you find.
Apr 29, 2010 | Princeton Digital VL1918 Monitor
A135s2276 screen is black.
Chances are the video card is bad if the display is black and the external monitor isn't showing anything as well.
Oct 07, 2009 | Toshiba Satellite A135-S2276 Notebook
I think I also have a bad power board.
Could be a bad fuse in the powerboard,ore look for bad caps...
Jun 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Princeton Monitor
There is a field of capacitors on the power board that usually goes bad. I believe that there is a total of 6. When you look at the power board you should notice them. I have the capacitors if you need them. $2 each. Just check to confirm that they are swollen. and let me know the voltage and uF. good Luck. David
Jul 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Ccfl inverter board
The most prevalent failure on these boards are the transformers and or the ic that controls the frequency of the lamp drive. More times than not you will find a bad transformer.
srich
May 19, 2008 | Gateway FPD2275W LCD Monitor
Monitor problem
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what is the problem of your LCD monitor. After you turned PC on and monitor stopped working or went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. You don't need to do anything with the inverter board in this case. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 20, 2008 | Gateway FPD1975W 19" LCD Monitor
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
390 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
