Question about Sony PlayStation Portable (PSP) Console
The up and down buttons on my psp are not working
  • 52 Answers
Some cables must be lose inside the psp. Get an expert to look at it.
Posted on May 17, 2010
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
How to restore default settings
Hello :
  1. Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait ten seconds and then replace the battery.
  2. Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
  3. Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings
  • If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
Or try this for hard resetting :
  1. Locate your Power button on your PSP. Push the power button up for 10 seconds.
  2. The PSP will and should shut off. Leave the PSP off for 30 seconds.
  3. Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
  4. Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
  • Do not have your PSP plugged into a power supply.
  • If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace .
PLEASE RATE !
Jun 08, 2010 | Sony PlayStation Portable (PSP) Console
Psp start button not workin home menu not either
try dismantling your psp and see the inside of it, you said you cleaned the buttons. try to see if the chips inside the psp are sort of dirty and stuff, the access points in wear the buttons touch, if this still doesn't work, just go to a original SONY STORE.
Apr 05, 2010 | Sony PlayStation Portable (PSP) Console
Trying to reset ps 2 to factory
Hello :
1: Remove the battery from the left side of the PSP while it is still onThe unit will power down instantly. Wait ten seconds and then replace the battery.
2: Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
3: Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings :
1: Locate your Power button on your PSP. Push the power button up for 10 seconds.
2: The PSP will and should shut off. Leave the PSP off for 30 seconds.
3: Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
4: Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
good luck .
please don't forget to rate !
My psp was working before but now it suddenly hanged up..i cant use it now..how can i reformat my psp?? do you know some ways???
Hello :
Warnings
Warning:
good luck .
rate please !
Mar 19, 2010 | Sony PlayStation Portable (PSP) Console
My psp files gone
I assume you have a PSP with customize firmware.
1. Turn on your PSP and press the "SELECT" button and the VSH Menu will appear.
2. Scroll down to USB Device and change the setting into "Memory Stick".
(Use the up & down directional button to scroll and use the left & right directional button to change the setting.)
3. Scroll down to UMD ISO MODE and change the setting to "SONY NP9660".
4. After you change the setting EXIT to the main console and restart your PSP.
If this solution did not work come back and we will try other solutions.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
Recovery Screen Not appearing
Hold the off button until it completely shuts down then hold the right shoulder/trigger button and at the same time turn the psp on! Hope this works for you!!
Jul 04, 2009 | Sony PlayStation Portable (PSP) Console
X button on PSP not working
then its not the games problem may the inside of your psp broke down and x wont work try to give it to a mechanic he/she might help you please vote for me cloud_foe:)
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
PSP start button and select button not work
  1. Connect the PSP to your PC with a USB cable. (about $10: buy a USB cable for your PSP)
  2. Press the "home" button on the PSP (it's a tiny button to the lower left of the screen) then use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
  3. Press the "X" button (you got it, the round button with the "X" on it) and your PSP should display "USB Connection".
  4. In a moment or two your computer should tell you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
  5. Click on the drive letter that corresponds to the PSP unit.
  6. Now create a new folder on that drive and name it "psp".
  7. Within the new "psp" folder create another folder, and name it "music".
  8. Copy your desired mp3 files into the new "music" folder.
  9. When you're done copying your desired music tracks, press the "O" button on the PSP to get out of USB connect mode.
Jul 16, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
