Question about Panasonic PT-47WX53 47" Rear Projection HDTV
My convergence is offline
I recently added DirecTV HD dvr and my picture is a bit offline. It gives me a good picture in the 480i, but on the 1080i it is a bit offline. Is there a code on the remote that I, myself can enter to fix the convergence. I had a repairman come out one time and he fixed it with the remote. Your assistance is greatly appreciated.
  • Panasonic Master
  • 8,617 Answers
The convergence needs to be adjusted for 480i then also enter into the 1080i and adjusted for that format. You would need the service manual for the parameters or you could severely mess your set up. You can purchase the full service manual for your set and get it emailed to you instantly by going to this link, they also offer free tech assistance if you have any difficulty when you purchase a manual. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Mar 30, 2008
SOURCE:
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
480i is displayed on the 62HM95 even when I play my Sony BluRay
I called toshiba (the television manufacturer) and they told me that the tv recognized the devices and then adjusts to the resolution according to the device of where its receiving the signal (HDMI).In this case my blu ray was not set to the 1080i resolution. Yesterday I set it up and BAM there it was.
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Picture goes goofy in 1080i
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Dec 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
