Question about Maytag Atlantis MDG6400AW Gas Dryer
Starts, turns, blows, NO HEAT
Starts turns blows no heat
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerstarts, turns, blows, NO HEAT - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Drstarts, turns, blows, NO HEAT - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 15, 2010
I turn my heat on in the car it blows out air but know heat
has your antifreeze ever ran low or needed to be filled I had the problem needed to bleed the engine sounds funny but it had to be done then I had the best heat ever
Dec 20, 2012 | 1997 Mercury Mystique
Heat is not working and van over heats when idling
first see if the fan turns on near the raideator it should turn on with the ac on then look for a blown head gasket auto parts stores have a tester kit to test it
Jun 08, 2012 | 2003 Pontiac Montana
1996 Saturn SL, Heater fan runs fine but no heat. Starts with a tad of heat then blows cold. Any ideas?
The plenum may be cracked, check for air blowing out where it should not, or the blender door is not opening, a cable sheath may have popped loose, or the heater core itself is clogged with leaf debris blocking air flow..
Jan 11, 2012 | 1996 Saturn SL
My heat won't get hot on my acura cl 3.2 2003. It will blow but not heat. A/C works fine. What happened?
turn the heat knob all the way to hot (highest) setting and when it starts blowing heat you can turn it down to a comfortable temperature
At least that's how mine works
Feb 14, 2010 | 2003 Acura 3.2CL
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heat sometimes works and sometimes doesnt
Make sure that your antifreeze is up where it should be.
Oct 18, 2009 | 2007 Chevrolet Aveo Sedan
Once i start my car and turn on the heat, it starts blowing in cold air until i get on the road and accelerate more, then the heat starts coming. but once the heat starts it only lasts about two minutes...
Hi Jens,
Two things are happening.
The first is normal. Your heater gets its heat from the coolant ciculating in your engine. In order for it to work, the coolant needs time to heat up a bit. This is true of just about every vehicle.
When it gets cold again is the puzzler.
My advice is to check the coolant level in the radiator.
ONLY when the engine has cooled.
If the level is down, there can be times when there isn't enough water to cool the engine, fill the radiator and the heater core. The result is the heater blows cold air and the engine runs hotter than normal.
So check the coolant. Open the cap. Start the engine and top it off.
Then see if there is a change.
Best regards,
Mike
Oct 16, 2009 | 2003 Jeep Grand Cherokee
Maytag Atlantis MDG6400AW Gas Dryer Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
