Question about Dryers
Electric Dryer The temperature does not change no matter what setting is used (ie Delicate, Med, High)....and the drying sensor does not seem to work.
  • 109 Answers
Is there enough heat? should be about 160 ^ f drying sensor can only be one of two things, make sure you didn't change wires when you reinstalled it or the timer is bad. may have multiple problems.
Posted on Mar 30, 2008
How to fix Maytag dryer MED9600SQ0
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jan 26, 2016 | Maytag Dryers
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Timer buzzes then shuts off dryer
you need to replace the timer if it is stopping the dryer before the end of the cycle.
Sep 30, 2009 | Maytag MED5600TQ Electric Dryer
Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Aug 11, 2009 | Dryers
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
Takes too long to dry or keeps running when clothes are dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
Kenmore dryer won't heat on low temp
Hi , the high temperature causes the heat sensor does not work properly , in delicate setting are having heat , the heat sensor are busted or open elements was not heating .
Jan 25, 2008 | Dryers
Dryers Logo
94 people viewed this question
Top Dryers Experts
