Brand new Front Loader not washing
Just bought a Whirlpool Front Load Washer ( WFS1071AW ). It will not wash. I Select a was cycle program and it starts for a couple of seconds and the the rinse & Spi/Drain lights come on and the Door open light is red and nothing happens. I have set it up correctly according to the instructions. It works on the rinse & spin cycle but will not wash.
  • Anonymous Aug 19, 2008
    red light stay's on, but when program set nothing happens.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Posted on Mar 30, 2008
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Can you show me a whirlpool WFS1071AW manual
The manual is available from the Whirlpool Australia site: http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001 . Enter the model number (WFS1071AW) in the box marked commercial code. Then select your language and click Search. The table of contents is starts on page 3 of the pdf.
I hope this helps.
Jul 09, 2011 | Whirlpool AWM6100 Front Load Washer
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrations in Whirlpool WFS1071AW
Hi the problem with your machine is the fact the transit straps have not been removed!! Remove them and you will not hear another thing from it. Look at the manual to find out how to take them off!
Dec 28, 2008 | Whirlpool AWM5125/1 Front Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Front Loader - whirlpool - does not star
machine controls may be locked. Power on the unit and hold in the far right button for 4 seconds and then try to select settings and cycles
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
227 people viewed this question
Top Washing Machines Experts
