Question about Car Audio & Video
My lighting audio b4.250.2 arnt turning on
So i hooked up my lighting audio b4.250.2 amplifiers to my subs and it was working for a day. Then the next day i had to jump my car because i left the battery on and now the amps arnt working. It is getting pwer to the amps but the amps arnt turning on. I also changed the fuses but its still not turning on. I dont know what wrong with it
    Problem Solver:
  • 13 Answers
You burnt them by jumping cables
Posted on May 14, 2010
Subs wont turn on
make sure there is correct wattage with the subwoofers and the power supply
Dec 07, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
if u r in the Tallahassee,FL area,call 850-339-1130,we repair all name brands of car audio Capital Audio & Electronics Repair
Mar 19, 2010 | Car Audio & Video
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Protect light
Does the amplifier do this when you don't have the sub hooked to it? If so, you have a pinch/short in your ground or power wire. If not, the subwoofer has a short in its voice coil or the amplifier needs to be repaired as it cannot handle a typical load.
Dec 29, 2008 | MA Audio HK401SX Car Audio Amplifier
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
