Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
New gas clean plugs..ran fine last year won't start this year?? am using 50:1 tho..
    Brigadier General:
  • 4,088 Answers
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
Posted on May 14, 2010
My six year old chainsaw won't start?
If it ran before you stored it and you left gas in it, you can thank ethanol for your troubles.Try fresh mixed gas with a heavy does of ethanol treatment or Seafoam in the tank, prime it and try to start it 10 times, then let it soak for a few days and try again. Good luck
Apr 03, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro 42 cc 2 cycle chainsaw ignition coils keep burning out
It is not common, but there are so many poor quaility units out there it does not surprise me.
Jan 26, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Ran out of gas and filled it back up ,now it won't start
If it has a primer pump this as many times as it takes to 3/4 fill the bulb, this will prime the carb, now try again with full choke.
Apr 09, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
Jul 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Difficult to start
Make sure the air cleaner is clean and oiled. this can cayse big trouble in two cycle motors, also if yo uare using fuel from last year dispose of it and start fresh, the gas will evaperate to a point even if it smells and looks like it is still there.
Mar 25, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Was not in use about 2 years. Right now could not start. What should i do to start the engine?
dump the gas - change the plug - get fresh mix - get and use starting fluid sparingly - clean the air filter, start pulling.
Oct 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 260 42cc. Need a manual.
For parts manual
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Hi and low speed jets are both 1 1/2 turns open, fine tune from there.
Apr 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
360 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
