Question about Belkin (F5D5231-4) Router
Internet lost intermittently
Router 'dies' and reverts to orange light on wire computers indicators. No warning
Internet lost, but still active when cable connected to PC.
Tried channel changing and cloning as advised by Belkin support.
About to launch said router - or buy a new one?
  • 176 Answers
Try to reset the router to his default configuration by pressing the reset bottom of the router for 15 second. try to connect using the router connection
Posted on Apr 16, 2008
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
I have a Belkin N600 HD (FD78301). It was working fine but after few weeks the light turned orange from green. I started having intermittent problems accessing the internet. The router has the...
Hi jaijeetc, There is no need to worry about a hardware problem. The orange light is just telling you that you didn't have an internet connection. So no, there is no need to worry about a hardware problem. Cheers, Alex
Jun 02, 2011 | Belkin Play N600 Wireless Dual Band Router...
When connect my WNR834Bv2 to a cable modem and the router to the computer, internet connectin drops, all LAN Ports are solid orblinking, what does this mean? Unplug in correct sequence, reconnect, same...
As per the information received it indicates that your router is rebooting intermittently. This clearly indicates fault with the router. I would recommend you to replace the router.
I hope this information allows you to resolve this issue. Please revert back for any more assistance on the same.
Feb 27, 2011 | NetGear RangeMax NEXT WNR834B Wireless...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Cannot connect to Internet. Orange light keeps blinking
The orange blinking light indicates that it cannot obtain the DNS server from your ISP (internet service provider). You must contact your ISP and check whether your service is active.
Aug 30, 2010 | NetGear WGR614 Router
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Nov 05, 2009 | NetGear WGR614 Router
Why is the status light orange instead of grren when the pc is turned off
You're pc when turned off should indicate that the CAT 5 cable (internet cable) is hook up to the router on the LAN port. It also indicate that you LAN has the capability to wake up or switch on the PC when properly configure with the keyboard.
Orange light indicates that the pc is on STANDBY status. If the ORANGE color is on the INTERNET LIGHT (which is the inverted question mark)...this indicate that you don't have any internet connection that is being given via modem from your ISP.
Sep 29, 2009 | NetGear DG834G Router
Belkin (F5D5231-4) Router Logo
111 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
