Question about Garden
My two part gas tank leaks what do i use to seal it with
    Brigadier General:
  • 4,088 Answers
If the tanks are plastic, the best fix is to replace them. Most epoxies, silicon, and other glue bases don't bond well with plastic and the vibration of the running saw doesn't help the repair either. Hope this helps!
Posted on May 14, 2010
How to fix a leak for gas tank(very small drip)
Hi, Thomas for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Soldeing repair on leaky tank Honda Shadow Forums Shadow Motorcycle Forum
Repairing fuel tank leak
Leaking gas tank from rust needs sealed What materials should use and how...
How to fix leaking gas tank
Apr 30, 2016 | GAS Motorcycles
Fuel Gas Tank Reservoir Selector Valve leaking when using front tank
The seal in the selector valve is bad on the front side.
Replace the valve or rebuild it.
Disconnect the battery ground cable before doing any work around gasoline.
May 01, 2014 | 1988 Ford F 250
How to fix leaking plastic gas tank?
I have fixed them with high grade epoxy and then fiber glassed over it
Jul 17, 2012 | Cars & Trucks
Leakin gas tank on Mod #PM 425 AV-18
Try sealing with PermaChem (I think that what it's called). It's a thick, sticky, fuel resistant compound that some in a small 4 oz tube. It never really hardens. It's made for threads. If this won't work than try Seal-All It will harden & should seal a cracked fuel tank, temporary fix for a fuel hose leak, etc. It can be found at Walmart, Home Depot, etc.
Jun 06, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My 1995 GSX600F tank is leaking and I cant find a replacement. Is the tank on the later model the same?
I am unsure as to a year to year match-up. Why not just coat the inside of the tank with "KREEM". This is a two part epoxy that you swirl around inside an empty gas tank then let set to harden. Rust is sealed and leaks are sealed.
www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
May 24, 2010 | 1995 Suzuki GSX 600 F (Katana)
Husqvarna 145 bt gas leak
the fuel line is cheaper to replace than the tank the most common problem with weed trimmers & blowers is the fuel lines will rot & leak if there is a small hole in the line on top of the tank it will poor out if i can futher help e-mail me @ wadembly@aol.com thanks , wade
Jun 08, 2009 | Homelite 'Yard Broom' Leaf Blower
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
May 29, 2009 | Homelite 'Yard Broom' Leaf Blower
AIR LEAK IN TOYOTA COROLLA FUEL TANK
Best bet is to replace gas tank. It could hae a hairline fracture somewhere. Sounds like pretty much everything else was replaced already.
Jan 12, 2009 | 1993 Toyota Corolla
Leaking gas
Some tanks have a fitting(s) molded into the tank, and filler attaches with a short piece of hose & clamps, others have a seal that filler pipe slides into for a tight fit. If it's the seal type & you can't pinpoint where leak is, you may have to pull filler out. Usually screws behind gas tank filler door, and out it comes but take a close look for anything else that may be holding it. You may have to twist & wiggle a bit but it should come. Inspect seal & tubes for nicks etc. If you have to re-use old seal, clean good, lube it & lube filler pipe before inserting back in to eliminate more nicks, and helps go in easier.Twist slightly going in too, makes it easier & helps reduce seal damage.
Dec 29, 2008 | 2002 Ford Mustang
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
