Question about Dishwashers
Will not drain on final cycle - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasherwill not drain on final cycle - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
All the water is not draining from the bottom of the machine. How do we fix it please?
It does not drain it has to be pumped out by the pump on both the wash and rinse cycles.
If the pump is not working on any cycle it has most likely failed and needs to be replaced.
If the pump is not drawing water out of the machine in the final rinse cycle only then there will be an issue with the electronic control board not activating the pump in the final cycle.
Nov 21, 2015 | Dishwashers
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking water at the end of cycle
Watch your drain line in the wall when the final pump out begins.
May be a sewer problem.
Start a cycle. After the fill, advance to final spin and watch drain in the wall.
Feb 25, 2009 | Whirlpool Washing Machines
Washer isn't properly draining in normal wash cycle and start/pause button has to be pushed to restart washer 2-3 times to finish cycle. When cycle finally finishes, a 'drain cycle' has to be run to remove...
remove bottom cover ckd pump for possible restriction..most have acess port on front if not remove hoses also pump impeller may be slipping on shaft or have broken fins
Jul 29, 2008 | GE Washing Machines
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
