Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw will run for 10 minutes then dies,will
Chainsaw will run for 10 minutes then dieswill not start again for about an hour. It is a 345
    Brigadier General:
  • 4,088 Answers
When it dies, try removing the fuel cap for a moment, then try restart. If successful, the tank vent is likely plugged (look under the left case cover). It should be a bronze plug set into the tank surface. If no help, remove the spark plug, and test for blue,snappy spark. If nothing happens, try a new plug first. If still nothing, remove the stop switch grounding wire at the ignition module and retest. If still nothing, the module is dying with heat--replace it using a thin business card for a gap gauge. Turn the flywheel magnets under the module poles and allow the new module to stick to the magnets, then tighten the screws. Rotate the flywheel to release the card, then turn the flywheel one complete revolution to make sure the module gap doesn't close up. Hope this helps!
Posted on May 14, 2010
Husqvarna 345 chainsaw cuts off when hot
It sounds like it may be getting lean at that point, and it could be something like a tank vent. When this happens, open the filler cap, close it, and see if the saw will start.
Another easy test is to fill the tank completely in the event that a small hole has formed in the fuel line inside the tank. I doubt that is the problem, but worth the time to check before moving on to other tests.
If that doesn't work, disassemble the carburetor and clean all passages with non flammable brake cleaner (carburetor cleaner can damage check valves and soft small engine components). Sometimes dirt can accumulate in places that affect how the diaphragm moves.
If none of this works, have a service shop evaluate the unit. Pressure and vacuum tests will reveal the culprit(s) and determine if the saw qualifies for service.
Mar 22, 2014 | Husqvarna Garden
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
Husqvara 345 chainsaw hard to start
try running it with out the muffler if ok without the muffler open it and clean the internal screen
Sep 15, 2012 | Husqvarna Garden
Chainsaw will run for 10 minutes then dies,will not start again for about an hour. It is a 345
When it dies, remove the spark plug and make sure that it continues to make blue sparks. If nothing, try a new plug. If still nothing, then the ignition module is likely dying from the heat--replace it. If sparks continue, then try spraying starting fluid into the plug hole, replace the plug, and try to start. If it pops once or twice, then suspect a fuel delivery problem. Try loosening the fuel cap for a moment, then try to start. If it runs again, suspect a plugged fuel tank air vent. Try cleaning the engine area with compressed air, particularly behind the starter mechanism. Hope this helps!
Mar 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Chainsaw starts off running strong gets hot and quits after 10
Remove the muffler and inspect the piston and rings. If there are any vertical lines or grooves in the piston or the rings, you must rebuild the top end of the saw. (including cylinder)
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
192 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
