Question about Canon PowerShot SD1100 IS Digital Camera
How do I un lock my card? Camera display syas card locked when I turn on the camera. How do I un lock the card?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Ask ko lng sana kung bakit me lumalabas na WRITE PROTECT pag binubuksan ko ung camera tapos di ko sya magamit pag merong memory card
It means that your writing capability on the memory storage device has been turned on. What you can do is disable it and check your memory card if the write protect is locked.
Cheers!
Apr 25, 2011 | Cameras
My camera displays "No SD card" when I do have a
Hello beach.... remove the sd card and check the perimeter of the card to find the locking mechanism. If the card is in the lock position, move it to unlock. Then reinsert the card, turn on the camera and go into the menu. Find format. Format the SD card and then it should be good. Joe
Thanks for choosing Fixya!
Jan 04, 2011 | Bushnell Trail Scout 11-9830 Digital...
Card Locked!
on the side it ses lock you have to un lock it theres like a butten
Jul 16, 2010 | Samsung S860 Digital Camera
The camera says in the screen that the card is locked The memory card is locked and I cant figure out how to un lock it is in the set up or what do I do ? my camera is EXILIM 8.1 Mega Pixels
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
Jun 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 19, 2010 | Canon PowerShot SD1100 IS Digital Camera
My memory card is locked how do i unlock it?
Pull out memory card from camera. on side of card there is a slide switch. The card should say what way to slide to un lock.
Good Luck
Nov 09, 2009 | Samsung BL103 Digital Camera
CARD LOCKED
Pull the card out of the camera and slide the tiny slide switch on the card to the other position. All the SD-type cards that I have met have this lock on them.
Jun 27, 2009 | Samsung BL103 Digital Camera
My Canon A460 Digital camera displays ''card locked''.
There is not many things that could cause this symptom. The card lock position mechanism is faulty and will require a replacement circuit board. Most likely about a 20-30 dollar part.
Nov 13, 2008 | Canon Cameras
Canon powershot A540
There's a little switch on the side of the SD card. Remove it from the camera and find the switch. Normally, there's some very small printing next to it saying something like (Lock / Unlock).
Mar 27, 2008 | Canon PowerShot A540 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
