Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also can I install this myself or will I need a technician.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
You can replace the inline fuse located under the communication connector. This will reset the fuser life counter. You will have to remove the fuser, remove the fuser bottom cover (one screw), cut out the fuse and solider in a new fuse. You must turn off and unplug the copier before you remove the fuser or you will cause a fuser error code.
Posted on May 14, 2010
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
Toner not fusing on minolta bizhub c250 properly, what is the cause
The fuser unit is faulty. The fuser heats the toner so it melts the toner onto the paper.
Nov 16, 2012 | Konica Minolta bizhub C250 All-In-One...
My machine says fusin unit need to be replace i replace ir already and nothing the message still in the scren waht can i do\/
you need to replace a whole new fuser or come with full new PIKO fuse to reset the fuser counter,
its useless if you change an used fuser,
Mar 14, 2011 | Konica Minolta bizhub C250 All-In-One...
How much is a fuser unit for a bizhub 250? I got a c3451 error.
around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
Feb 22, 2011 | Konica Minolta bizhub C250 All-In-One...
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
I have bizhub c250 and the 83000 prints (copies). My Fuser unit show empty and I can't use my bizhub c250. it should be replaced on 120 000 copies. How to reset this fuser unit on my printer?
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Nov 04, 2010 | Office Equipment & Supplies
Printing PDF to Bizhub c252 issue
I had this once. We simply deleted the Printer Driver and reinstalled it. Also, when reinstalling the Printer Driver we chose the PS (PostScript version).
Try that - hope it helps
Kind regards
m-press.biz
Apr 26, 2010 | Konica Minolta bizhub C250 All-In-One...
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also, can I install this myself or will I need a...
These are not too bad to replace yourself if you or someone you know is at all mechanically inclined. As far as used, you would probably spend the same for one plus shipping as you would for new. Or at least close enough to make it not worth it in my opinion. precisionroller.com has them for $257 with free shipping. Part# H1895
Hopefully this helps and just holler if you have any further questions.
Mar 19, 2010 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Reset fuser
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
May 28, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
252 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
