Cd dvd drive
My cd/dvd drive isnt detecting any type of discs since my 3yr jammed a dvd disc into the drive im just wondering if its worth getting ot repaired or just buy a new laptop?
    Scholar:
  • 105 Answers
Yes its easy to repair / replace the laptop drive. I'm in the UK and charge £30 for a replacement CDRW/DVD and £45 for a DVDRW A new laptop would cost about £300 depending on the make and model. Keep green and get the item repaired.
I hope this is useful please rate the solution as we depend on your feedback.
Posted on Mar 29, 2008
SOURCE:
I have a memorex 700MB dvd/cd , i made a video for my family for christmas and ever type i press burn it says disc type mismatch... i need help! please.
You need to use a DVD+R disc or a DVD-R disc to burn a video. It sounds as if you have made a DVD type video and put a CD-R in the slot and your burning software is detecting that and refusing to put the data on the disc, knowing that it wouldn't play on a DVD player.
Look at the front of your dvd drive - if it has a "DVD" symbol with an oblong disc below it and says "-R -RW" then you need to use a DVD-R disc. If it has a symbol of a big "RW" then you need a DVD+R disc. If it has both, then you should be able to use either one.
Dec 18, 2010 | Computers & Internet
Drivers not working. Can not play any dvd,cd's.Its been about a week. Reinstalled drivers on Help and Support, but still not working. Any Ideas?
When you say Drivers not working, can you please confirm if you are referring to the CD Drives ?
If yes you can first make sure that the Drives are detected in Windows Explorer.
Click on Start Then click on "Computer" or "My Computer"
See if the CD / DVD drive is detected
If the drive is detected in Explorer and not able to read the discs, try various discs of different brands.
If none of the disc is readable then the Drive is gone back and you will need to replace it.
In case the Drive is not detected in the Windows Explorer then you can check if the device is detected the Device Manager.
To open device manager Press the Windows key + R and type devmgmt.msc
Press Enter of click OK
It will open the device manager
look under CD/DVD drive if there is any yellow exclamation mark.
If you see the Drive listed with an Exclamation then follow the steps to delete lower filter and upper filter from the Windows registry Editor.
http://support.microsoft.com/kb/929461
Jul 17, 2010 | HP Computers & Internet
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
DVD not detect at bios. why
if you press enter or space when you have an item highlighted does it not give you the option to add the dvd / cd ?
On some bioses it is there its just that its been disabled as an extra boot device to speed things up so that its not always trying to read or find a cd to boot from so if you press the key it requests you to ( near the bottom of the screen when you are in the bootable devices section ) it will explain how to alter or add them. If you follow the instructions you should be able to add it as a bootable device
If its not detecting any discs in the drive whilst in the bios thats because you need to save the settings in the bios to boot from the cd / dvd and the disc ( cd or dvd ) has to be made bootable and then once the bootable disc is in the cd / dvd drive and you have saved the settings in the bios and restarted it should boot from the disc thats in there.
If you need to make a disc bootable you can either use nlite or you can get guides on how to make a disc bootable if you search google.
Your operating disc and a linux disc(s) are all bootable
Apr 17, 2009 | Toshiba Computers & Internet
Do not read the cd or dvd disc.
Its zamzam,i wud suggest you buy a new one from a better manufactuerer.
Aug 19, 2008 | Computers & Internet
Dvd/cd drive not working
my dvd cd1.gif drive in my laptop1.gif isnt working at all i can hear it start when i insert a movie or disc but then it stops and when i check for the driver in my
Feb 25, 2008 | Computers & Internet
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Open Questions:
Computers & Internet Logo
119 people viewed this question
Ekse
Alun Cox
