Question about Areca ARC-1212 4 Port SAS RAID Controller - 256MB ECC DDR2 - PCI Express x8 - Up to 300MBps per Port... Serial ATA Controller
ARC-1212 4 Port SAS RAID Controller - 256MB ECC DDR2 - PCI Express x8 - Up to 300MBps per Port... Serial ATA Controller: How do you boot a Mac Pro 2009 from a volume on th...
How do you boot a Mac Pro 2009 from a volume on the ARC-1212?
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Areca ARC-1212 4 Port SAS RAID Controller - 256MB ECC DDR2 - PCI Express x8 - Up to 300MBps per Port...  Serial ATA Controller Logo
Top Areca Computers & Internet Experts
David Payne
David Payne
Are you an Areca Computer and Internet Expert? Answer questions, earn points and help others
