Question about Empire DV-55 Heater
I need a gas valve for this unit Empire DV-55SPP.It is lp gas.are there any web suppliers?
  • 494 Answers
Here you go. The link to suppliers to buy Empire heater parts.
http://empirecomfort.com/EMPIRECOMFORT/pdf2008/Master-Parts-Distributors.pdf
Posted on May 18, 2010
Need a gas valve for empire DV352SG S/N T49918889 was there a recall on this gas valve?
Being an ECS dealer, I'm not aware of a recall. The following link will give you a list of master parts dealers that you should use, if your heater is no longer under warranty. Select the one closest to where you live. http://www.empirecomfort.com/EMPIRECOMFORT/pdf2010/forms/Master-Parts-Distributors.pdf
If your heater is still under warranty and you still have your Proof of Purchase. Order the part through your local Empire Dealer.
Hope this helps you get the gas control valve you need.
Apr 15, 2011 | Empire DV-35 Heater
Furnace lights right up, but will not shut off with on-off switch or thermastat switch? checked out the thermastat switch and that works fine.
Disconnect the thermostat wires from the gas valve, if unit still runs; you have a short in the gas valve and it needs to be replaced.
Feb 22, 2011 | Empire DV-215 Direct Vent Natural Gas...
Do they make a conversion kit to switch from natural gas to lp for a DV-55 furmace
Yes they have conversion kits for your furnace. You will need more information along with your DV-55 there should be a combination of two to four numbers and letters.For complete parts breakdown and ordering info. go to www.empireheaterparts.com. Hope this helps you. I have a couple of old empire units that i've used for 15 years.Good heaters. Thank you.
Nov 05, 2010 | Empire DV-55 Heater
I need a gas valve for this unit Empire DV-55SPP.It is LP gas.Are there any web suppliers?
Try empireheaterparts.com-------The new valve should come with a LP converson kit if not already installed.
Mar 19, 2010 | Empire DV-55 Heater
Empire Mod#UH-1250-1FSP Ser # K49789WR Heater has been switched from LP gas to natural gas. I need proper orifice size to complete.
need to notify empire their specs for their natural gas should have the answer the kit or conversion unit should have had the part -it might not need to be changed--but if it does info needed is size of heater btu's size of line what kit/gas valve unit ur using
Jan 25, 2010 | Empire Heating & Cooling
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Sep 04, 2009 | Empire DV-35 Heater
Empire DV-215 Low Flame Issue
Either a restriction in the gas train, low gas pressure or a bad gas valve. Check the pressure on the gas line when on pilot and again when the burners are running. Depending upon what type of gas it runs on, you should have at least 4" W.C. if Natural Gas and 10" W.C. if Propane. If gas pressures test good and all valves are open, you are looking at replacing the gas valve.
Dec 08, 2007 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
113 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
