Question about Kitchen Ranges
Need a Wiring diagram for a retrofit ERC3B(WB27T10174) Art
1961 Triumph Bonneville T120 wiring diagram
Hi, Arthur for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Triumph, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1961 Triumph Bonneville T120 wiring diagram Google Search
Wiring Diagrams
http://www.classicbike.biz/Triumph/Repair/56-62Triumph.pdf
http://www.classicbike.biz/Triumph/Parts/1960s/65Triumph650ccPartsManual.pdf
Apr 13, 2018 | Triumph Motorcycles
I have an early version of a ew36 scooter and need to retrofit a speed pot. How do I do this, and any other info or schematics would be great. Thanks
The manufacturer has a variable speed control on the latest version of the ew36. My best suggestion is to contact the manufacturer for the part if it was not available on your version. They may have a retrofit kit with the harness and schematic so you do not have to reinvent the wheel or damage the existing components. You may need a new console cover where the speed control is mounted near the throttle lever. The manufacturer has done the work already and should provide the best guidance. Under driving the digital electronics with a home grown component may produce poor performance and potentially damage the controller sensing circuit. Hope this helps.
Jun 25, 2016 | Health & Beauty
Clock does not work
You will need to replace the control board. Here is that part to order.
Oven Control ERC3B
Mar 18, 2014 | GE Profile JDP47 Electric Kitchen Range
I have 2010 Ford Taurus SHO seats. I believe they are 8 or 10 way memory seats. Trying to retrofit for a street rod. Have a few wiring diagrams but not enough. Can't get power to any motors yet. Numb
Problem Solved !!! I traced every wire, Bought manuals, Ended up buying a passenger seat wiring harness and removed driver memory control module plus harness. Installed new passenger harness and it works great ! You need VIN# when ordering part, Order number is slightly different then number on wire harness but when it came in numbers matched. AU5T 14D230 J4CP7
Nov 15, 2013 | 2010 Ford Taurus SHO
Toyota 86120-37010 am-fm radio wiring diagram
Can I have the wiring diagram as well? this is a question to Toyota Ed..
thanks
Art
Mar 14, 2012 | Cars & Trucks
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
Where do you recharge the airconditioning unit on a 98 jeep grand cherokee 4x4 loredo? Need the location of the fill valve. I already have the recharging kit.
Jeep GrandCherokee SUVs manufactured in or before 1995 use R12 refrigerant. You must retrofit these SUVs to accept R134 refrigerant using a retrofit kit available at your local auto parts store before you can recharge the system. In some areas, a license is required to retrofit an air conditioning system. If this is the case in your area, take your Jeep to a professional to retrofit the system.
Instructions:
  1. Step 1 Take your SUV to a mechanic to recover the R12 refrigerant out of the air conditioning system. A license and special equipment are needed to do this. Because R12 refrigerant is expensive, many mechanics will do the job for free.
  2. Step 2 Locate the Low Pressure Side connector port. You will find it on the driver's side of the engine. Remove the blue or yellow cap marked L. You only need to retrofit the system if you see a screw-type connector valve. If you see a quick connect valve, the system already is R134 compatible. Wipe the connector valve off with a clean towel. This ensures that the retrofit connector properly adheres to the valve.
  3. Step 3 Place the long retrofit connector from the automotive retrofit kit onto the Low Pressure Side valve. The retrofit connector has a special adhesive on the threads that will help it adhere to the valve. Screw the connector onto the valve. Tighten the retrofit connector using an adjustable wrench. Place the cap provided in the retrofit kit onto the retrofit connector. This keeps dust out of the system.
  4. Step 4 Follow the air conditioning lines away from the compressor until you see the High Pressure Side port valve. This is located near the Low Pressure Side service port. Remove the red cap and wipe the port off with a towel.
  5. Step 5 Put the shorter adapter onto the port. Twist it using an adjustable wrench until it is securely fastened to the port. Place the red cap from the retrofit kit onto the adaptor.
  6. Step 6 Fill out the Retrofit Identification sticker provided in the retrofit kit using a permanent marker. Remove the protective backing and place it on the interior side of the hood. This lets future owners and service professionals know that the system has been retrofitted.
  7. Step 7 Recharge the air conditioning system. See the related eHow titled "How to Recharge Air Conditioning with Freon in a Jeep Grand Cherokee."
WARINING:
Never try to evacuate the system yourself. A license and special equipment is needed to evacuate the system. Attempting to do this yourself will release refrigerant into the air, which is a federal crime.
Good luck (rated this help).
Aug 10, 2009 | 1998 Jeep Grand Cherokee
Blowing fuse for A/C, what is BSI fuse for?
how do i replace a retrofit kit for the air conditioning system. unscrewing the stem is troublesome. Any ideas?
Jul 07, 2008 | 2001 Jeep Grand Cherokee
Kitchen Ranges Logo
166 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
