Question about Sammons Equipment SAM-2238HPINUA9 Moisture Control Hot Humidified Cabinet
Excess water in fridge cabinet
We have a westinghaose cyclic defrest refridgerator. The cabinet is always wet and containers have a lot od condensed water in them. The drain tray freezes. The temperature control is set on 2 and the thermometer indacates about 5degres celcius
Many thanks
Lloyd
Please note that I did not ask for "a solution for the Sammons Equipment SAM-2238HPINUA9 Moisture Control Hot Humidified Cabinet Problem ". My question related to a Westinhouse refrigerator.
Thanks
Lloyd
Posted on Mar 30, 2008
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Condensation
There is no"filter" underneath. There is. however, a tray underneath your fridge, designed to catch any excess water. If you remove the bottom louvered piece in the front on the fridge, you will find, probably on the right hand side, a tray which is engineered and designed to catch any excess water (as if the fridge were defrosting), but there is no "filter" which I know about. Refrigerators are pretty simple machines. They don't typically require lots of maintenance, but they do require monitoring here and there.
Jan 18, 2018 | Beverage-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
There is water in the refridgerator
You have a disconnected defrost drain pan. You will need inspect the ceiling of your refrigerator compartment and find the drain hose going from your freezer to your fridge then the drain pan. Sometimes this is molded into the plastic at the back of your fridge and it simply leaking out the joint. Start by defrosting your freezer, then pour water in the freezer itself while checking the ceiling of the fridge for water traces. Keep a wet/dry shop vac handy or a mop to keep up with the excess drainage. Then reattach the hose to the little drain nozzle when you find it.
Mar 13, 2010 | SUMMIT Professional FF1615SS Refrigerator
Why do i have water in my refridgerator
Air contains water particles and it will condense to form solid ic, you have to defrost your refridgerator on a regular basis and have to watch the water is drained up to the maximum extent
Dec 17, 2009 | Kenmore Refrigerators
Water leaks from underneath
Make sure your drainage tube is not plugged.
Check inside the back of your fridge to make sure the little cup that collects condensation from your freezer compartment is not plugged with food or ice.
(I had that happen in my fridge,different model). I had lots of water on the floor of the fridge until I found this solution here on fix-ya.
Also, make sure your fridge is set right for the the humidity levels you have may experience.
Get a hold of the manual for your fridge if you don't have it, and make sure freezer is not too cold.
If you have a lot of condensation on the outside of your door, look inside your freezer and try some different settings.
I'm not sure if this helps at all. Try blowing with a blow dryer on your condensation container area on the inside of the fridge.
I'd love to know if this helped.
Aug 26, 2009 | Frigidaire FRT18B4A Top Freezer...
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Beco larder fridge - excess of water in drip tray at rear - fridge cold but items in fridge are heavily condensed
you have air leaking into the fridge. check door seal by trapping a slip of paper between seal and cabinet all way round
Sep 17, 2008 | Refrigerators
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
Sammons Equipment SAM-2238HPINUA9 Moisture Control Hot Humidified Cabinet Logo
180 people viewed this question
Top Sammons Equipment Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sammons Equipment Refrigerator Expert? Answer questions, earn points and help others
