Question about Home Security
Just bought new house got an alarm challenger optima g4 no codes so ive just cut the live wire to it could do with it working help
2 Suggested Answers
szanti
  • 36 Answers
SOURCE: Optima G3 alarm - how to change the alarm code
This is where you will find the manual for your alarm system
Please let me know if this helped
http://www.tlc-direct.co.uk/Technical/DataSheets/Ade/4pi175_A-G3_inst.pdf
Posted on Dec 06, 2009
Wire together fire alarms
If you wire fire alarms together you may not have the coverage you should have. If you have a fire alarm in one part of a house and put another one hooked to it then if a fire puts the power out in that part of the house then you have no protection in the other part if it's on the same circuit. There has to be a different circuit for each alarm.
Sep 09, 2014 | Home
Accenture alarm
Default code for ade accenta panels is 0123
Feb 07, 2014 | Home Security
Brand new door contacts on my wired alarm system not working properly
1. Make sure you have a (EOL) resitor on the curcuit, it should be at the switch, but you can cheet and have it at the panel, but if your wire would ever get damaged you would not know about it 2. If you had to hammer in the switch it could have damaged the switch to a closed state and wont open when the door opens, the switch should just be pushed in not hammered 3.If the switch is installed to close to a magnet wheather stripe, that will hold the switch close 4. If it is a steel door and steel frame, and the switch is a surface switch with screw terminals, you could have some stray wires shorting to the steel frame 5. make sure your magnet is lined up with the switch
Jan 05, 2013 | Honeywell Home Security
Change nsin alarm code
Any one got a instruction book for one of these alarms carnt find mine and carnt remember how to re program it
Nov 18, 2012 | House Brand 2x Intrud Alert House Alert...
Nov 26, 2009 | Home Security
Removed alarm system; now phone won't work
In the alarm system there was a jack called an RJ31X. This jack is suposed to have the line run from the teleco interface to it and then back out to the rest of the house(except for DSL, it stays ir front of the alarm jack). When the alarm jack was cut out the line bridge was eliminated. To make the line active find the wire that went to the alarm jack and and connect the red wire to the yellow wire and the green wire to the black wire. that should pass the line through to the remainder of the jacks in the house.
Oct 13, 2009 | Lands Phones
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:
https://portal.gesecurity.com/portal/login/login.jsp?TYPE=33554432&REALMOID=06-0008ce40-a18c-1536-85ea-8312f762000e&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$https%3a%2f%2fportal.gesecurity.com%2fportal%2fmdme%2fDownload.jsp%3fID%3d320%26DID%3d320%26documenttype%3dInstallation$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
How to remove a front stud on my kia optima
You should see a cut out section where the caliper was mounted rotate the hub. to this cut out . There should be enough room to slam it out.
Jan 27, 2009 | 2004 Kia Optima
Optima house alarm
after a power cut alarm goes back to factory setting 0123. you need to use this code to re program alarm
Jul 31, 2008 | Computers & Internet
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
