My Dell 1721 laptop appears to have overheated/will not turn on.
My Dell 1721 laptop appears to have overheated and will not turn on. The fan will start and run for about 5 seconds and then turn off.
  • 721 Answers
There's no easy solution for the laymen on this one. All Dell's come apart the same way for the most part. If you go to Dell's site & either enter the service tag or just select your model. Download the tech service manual for a reference. Before you start the next step, take the ram cover off & take a stick of ram out one at a time & try to boot. If it boots that ram stick is faulty. Now for the quick instructions for dissasembly. Disconnect all power, a/c & battery. Using a small flat screwdriver, like a jeweler's, remove the hinge cover above the keyboard. Remove the keyboard,taking note to the ribbon cables for the mouse pad & keyboard. Turn the unit upside down & remove all screws, some maybe under rubber or plastic cosmetic plugs. On most you can leave the hard drive in, if it's easier,just pop it out. Flip the unit back over & the large plastic with the mouse pad & such should pop off with limited effort. Now some have a metal shield covering the guts,remove the 2 or 3 screws holding that in place.There should be a nice,clear shot at the cpu heatsink & fan. You'll need a tube of thermal paste found at the local radio shack to do this part. Remove the 4 screws holding the heatsink/fan assembly & wiggle it off the cpu,also unplug the fan. Seperate the the fan from the rest of the heatsink & use compressed air(dust off) to blow the giant glob of dust that is probably in there out. Put a dot the size of a bb of thermal paste in the center of the cpu & re-install the heatsink/fan assembly on to the cpu.Before you put it all back together, simply plug the battery in or a/c adapter & power the unit on. If it makes it longer than 5 seconds & you can see the cpu fan working, then it's fixed. If not, it's too late for this motherboard. See if there's any warranty left on the laptop by going to Dell's site & entering in the service tag number.
Posted on May 15, 2010
How can i connect my dell inspiron 1721 to my tv samsung led
If your Samsung TV has a VGA input then connect a VGA cable to the TV and the other end of this cable to the video port on your Dell laptop. Turn on your TV and select the VGA (computer) input then boot up your Dell laptop.and then the video data from the laptop will automatically divert to the TV.
You can toggle between the TV and laptop LCD screen by holding down on the Fn key and press the F8 key.
Jan 26, 2013 | Dell Inspiron Computers & Internet
Cpu fan wont come on dell inspirion 1721
it shows that the may gone out of order needs replacement
Jan 14, 2013 | Dell Inspiron Computers & Internet
My Dell Inspiron 1721 has a loud grinding fan problem. I already had the fan cleaned and had a new motherboard installed. Now this fan is making a loud grinding sound after 20 minutes of being online....
Hi Friend, In this case I would recommend you to please try and update the BIOS of the system. Please follow the below link to update the BIOS, but please make sure to select the Operating system first in the link and you will see corresponding drivers for that Operating system
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1721&os=WLH&osl=en&catid=&impid=
Please let me know if it was of some help.
Thank you,
Feb 01, 2011 | Dell Inspiron 1721 Notebook
Monitor is dead when I turn on the laptop.
Press D + the Power button this will run the LCD BIST Test. If you gt 4 solid color screens, then the LCD works. If no screens appear then the LCD is bad
Sep 03, 2010 | Dell Inspiron 1721 Notebook
Hi there!
For that problem of yours, you can only try a few things since its shutting down by itself,
First, Try to use just the charger to turn on the computer, if it does the same thing then unplug the charger and then this time just use the battery,
If the same thing happens then double check the charger if there is a light on it or of you have another
charger use it.
But after all of this things and the same thing happen,
You may want to check if you still have a warranty
under DELL because you'll need to replace the Motherboard of the computer.
Hope this helps!
Mar 19, 2010 | Dell Computers & Internet
When I hook my 40" samsung lcdtv to my dell inspiron 1721 laptop through the vga cable...the connection cuts in and out. It will appear on my screen...then go blackm and then back on again.
try configuring your display settings on the laptop before connecting. I have a HP dv7 and it was doing the same thing until i configured it for a secondary display
Dec 11, 2009 | Dell Inspiron 1721 Notebook
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
How to change computer keyboard key on dell inspiron 1721
Dear sir
in the link below you will find the complete spare part solution for the Dell Inspiron
http://www.user-guides.co.uk/cddownload/Dell/DellInspiron/Dell-Inspiron-1721-Service-Manual-Remove-Upgrade-2289.html
and you will learn how to install the Dell KB in
Sep 22, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
My backlight has turned off on my dell 1721
Most probably your LCD works fine but backlight is not.
Send it to service for back light replacement / connection fix.
Jul 08, 2009 | Dell Inspiron 1721 17" Notebook PC, AMD...
Dell 1721
Hi Tom,
The Inspiron 1720 &1721 series was released more than a year ago and is no longer available new, only refurbished. The comparbable machines currently on the market is the Inspiron 1525 & 1526 series. The 1525 &1526 series are comparable in price and specs, and the specs are a little better as far as graphics and sound cards. The 1730 series is still available, but it has a price of approx $2500. Hope this helps. If you have any more questions feel free to ask.
Pyrhyc
Jul 21, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
