Question about Lands Phones
Newly purchased phone
Answering machine will only work if set for 2 rings, otherwise if reverts to an old greeting that was on my previous phone and will not receive a message.
I recorded my message on my machine but when a caller calls only last part of the message is heard.
Posted on Sep 01, 2008
SOURCE:
How do we program answering machine on dect 1735 cordless phone
Do you mean the Uniden DECT 1735? You can turn on the answering system from the base On/Off button. The rest takes the hanset or a call into the phone. Start with the phone in standby (no handsets in use). Press Menu on a handset. Use the Up/Down arrows to navigate to Answering Setup and press Menu again. To set the number of rings, navigate to Ring Time and press Menu again. Use the arrows to select a number of rings and press Menu to save. Press the Left arrow/Page key to go up to the Answering Setup menu. Press End to exit the menu system.
To set the greeting, you would navigate to Record Greeting in the Answering Setup menu. Press Menu. When you hear "Record Greeting", speak your message. Press Menu when you finish. Press End to save the message after you hear it repeated. Press Menu and wait for the "Record Greeting" prompt if you need to change the greeting.
The manual for this is available on the product site: https://www.uniden.com.au/product/dect-1735-2/. The direct link to the manual is currently https://www.uniden.com.au/wp-content/uploads/2017/06/DECT_17352_OM.pdf . See the section starting on page 20 for the different steps to set up the answering system.
I hope this helps.
Apr 15, 2018 | Dect Lands Phones
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
I cannot find how to set the number of Ring Count on my phone AND How do I set my personal Greeting for the answering machine? I've tried for 3 weeks using my 'operating instructions manual'
The manuals can be overwhelming. The KX-TGC210
manual obtained from www.manualslib.com has the
Answering System details beginning on page 29.
==============pg 29================
To summarize, "Recording your greeting message:"
press [menu] # 3 0 2
scroll to "Yes" press [select]
phone will (beep) [[ speak your message ]]
press [ stop ]
press [ off ]
==============pg 32================
To summarize, "Number of rings ..." (Ring count):
press [menu] # 2 1 1
scroll to ((your desired number of rings)) press [select]
press [ save ]
press [ off ]
May 21, 2016 | Panasonic Lands Phones
How do I make answer message
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
May 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
How to set the tax
First, to make sure it will work, your fax machine should be going directly to the phone jack, with the answering mach/phone (if any) going to the ext port in the back of the fax machine. That way, the fax machine can "eavesdrop" for any fax tones for every call. If you want to use the fax machine to work with an answering machine on the same line, make sure to set the answering machine to 2 rings lower than the fax machine. Let's say, you have the answering machine set to 4 rings, your fax machine then should have 6 rings. You can set the number of rings for your fax machine under "basic fax setup" of the "menu". Otherwise, you can set the fax machine to auto answer by pressing the auto answer button.
Apr 04, 2011 | Office Equipment & Supplies
I need an answering machine with 2 OGM for distictive ring svc.
My solution is that i am willing to purchase this phonemate 9870 for a nominal price if it works.
Apr 01, 2010 | Lands Phones
I need to set the rings
Rings to Answer:
THIS SETTING ALLOWS YOU TO SELECT THE NUMBER OF RINGS BEFORE THE UNIT ANSWERS A CALL.
1. The unit announces, "Rings to Answer (the current rings to answer setting). To set rings to answer press NEXT. Press SET to continue.
2. To chantge the rings to answer, press and relase the NEXt OR GREETING/PREVIOUS button and the unit announces a number, such as "2,3,4," or "2, toll saver, 5."
3. After choosing a number, press and release the STOP/SET button to store the rings to answer. The unit confirms the setting and enters Message Length menu.
Taken directly from the instruction booklet that came with my GE 29888GE1 instructions.
Hope it works for you ! jp
Mar 02, 2009 | GE 29888GE1 Digital Answering Machine
I have a GE29869GE2 Answering machine, no instructions anymore. How do I change the number of times the phones rings before receiving the greeting kicks in?
1. Press set button
2. Use next and previous buttons to select number of rings setting and press set.
3. Select the number of rings you want.
4. press set again to save setting.
I hope this helps. Here's the manual:
29869GE2 Digital Answering Machine
Dec 13, 2008 | GE 29869GE2 Digital Answering Machine
Changing greeting on answering machine
Hold the greeting button down. Follow the verbal instructions the phone will give you.
Feb 19, 2008 | GE 29893GE1 Corded Phone
Answering machine hangs up during greeting
this problem is cause by excessive loop current from telco. the answer to this is to put a 600 ohm resistor in series with either tip or ring to the cable which feeds the answering machine. excessive loop current related issues can be the toughest problems to troubleshoot
Oct 14, 2006 | Vtech i5871 Cordless Phone
Lands Phones Logo
64 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
