Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Lost everything! Turned on my MP3 after a trip to the gym, and nothing! it is saying there is no music. i have tried going via playlist, artist, and album. it just pops up "no song" how does this happen? it wasnt hooked up my computer, so i have no clue what went wrong!! help! i am in tears here!! thanks
  • lcrane3 Apr 20, 2008
    I have the same problem and im very upset!!! Lost all my songs and it says "no songs"
  • 8,596 Answers
If you have the Sansa firmware upgrader installed, any firmware upgrades will cause all songs on the player to be lost. There are other reasons, but this is the most common.
Posted on Apr 07, 2008
SOURCE:
Can't catagorize the music into files or playlists....?
okay, once you downloaded the file via Frostwire...you tag the file (name of track, artist, trk #, album name, genre and year) right...all this is in the folder where you downloaded...not using windows media.......lets skip that and go straight to the mp3 player...yep copy/paste or click/drag to mp3 from the PC...now your files are already tag ...this should help sort the file by any catagory you want to........
feel free to rate the help
Apr 01, 2010 | Sony NWZ-E438F Digital Media Player
Will not play music continuously.PLay 1 artist then stops.
This is not a problem with the iPod. it's supposed to do that, probably to save batt life if you fall asleep or something :S.
If you want everything on your iPod to play continuously then select the shuffle songs option from the main menu (should be there by default).
Alternatively you could create a playlist of all the artists you want to hear by highlighting them and holding down the center button for about a second then go to playlists and it will be listed as on the go. go into this, save it and play.
Sep 03, 2009 | Apple iPod MA446LL/A MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Playlist Problem
There is no firmware to fix this issue. I pored through the documentation, and there is nothing that says it will max at 400 songs. Make sure the playlist was loaded in msc mode - the manual suggests it - and that all of the songs are in the correct format. It may be an endemic limit of the unit.
Jun 08, 2008 | Insignia Pilot MP3 Player
2nd G - Nano: Music syncs from Itunes but not playable
click on the ipod on the left and go to music, also maybe creating new playlists might help??
Apr 22, 2008 | Apple iPod nano
Samsung K3 mp3 player
To erase a music file, you must plug the K3 into the computer, and when a window pops up that says "Open in Folder", "Open with Media Player", etc. Choose "Open in Folder" then go to "Internal Storage", then choose "Music". From there, you can delete by artist, or if you click on a folder that has an artist's name for the title, you can erase by album. From there you can erase by track by double clicking on an album folder.
To erase, right click the folder you wish to delete, and select "Delete".
Apr 12, 2008 | Samsung YP-K3 MP3 Player
Freezing
Refresh the database. It's under settings.
Jun 27, 2007 | iRiver H10 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
