Blown Pioneer Amp
Hi I have a pioneer a-447 audio amp. The other day i turned the power off at the amp on/off button and the speakers emitted a god almiiiiiiiiiiiiighty bang.
Since then the amp powers-up but no sound out. I have checked fuses and looked for any obvious signs of shorts or damage, nothing obvious.
In order of probability what should i be checking and how?
cheers
glenn
    Genius:
  • 1,550 Answers
Cambia los ICs amplificadores de audio
Posted on Apr 04, 2008
No audio on A-speakers Pioneer VSX-504s
its either the wire to speaker B,the speaker,or most like the amp,has blown an anoid
Jul 22, 2016 | Pioneer Audio Players & Recorders
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
While watching TV (all audio ran through my Pioneer VSX-516), the receiver shut off by itself, so I powered it back on. Then it powered off again a couple mins later, and wont power up at all now. I...
Try holding the "advanced surround" and "enter" buttons and see if it turns back on. If it shuts off again, disconnect all speaker wires and try it again. If it stays on, you have a bad speaker or wire. If it still shuts down, the amp is blown and needs to be repaired.
Mar 29, 2013 | Pioneer VSX-516-K
Pioneer GM-6200f amp no audio - flashing light
Hello! Yes, It certainly looks like the output power circuit has blown.
I wish I had better news.
Guru................saailer
Jan 12, 2010 | Pioneer GM-6200F Car Audio Amplifier
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Shorted a speaker wire together
Check the fuse. If its not blown rewire the ground to bare metal.  make sure the power wire is the right gauge aand connected right
Jul 16, 2008 | Power Acoustik LT-980/2 Car Audio...
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
218 people viewed this question
 Grubhead
Grubhead
