Question about D-Link Rangebooster G USB Adapter (WUA2340)
D-LINK MODEL G-WUA-1340
I recently move and change my internet company from verizon to optimun cable, I set up a network for home all my computer work with wireless adaptafors and the wireless router but my son's computer was not working properly until yesterday that it could not get connection or signal, then is telling me that they so not have a wireless network adaptador , I disconnected the d-link and when I put it bach the computer does not recognized it or read it, I tried other usb ports but keeps telling me the same do you think I shoul get another adaptador or is another issue? Thanks
Patricia
  • TruckNoob Mar 04, 2009
    The same model too. (D-link WUA-1340 Hard Ware ver A1 Firm Ware 1.00)
    I have the drivers installed. It worked for several days. Then windows couldn't recognize it anymore. No lights come on, on the USB wireless adapter. I think it's dead.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    nope..you'll need a wireless driver for your computer. what make is it?
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Posted on Feb 27, 2009
vincent721
  • 240 Answers
SOURCE: I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Posted on Mar 13, 2009
  • 18 Answers
SOURCE: WiFi works fine, but no internet
please open a comand prompt and try to release the ip and renew the ip. check is the Ip changing.
or
turn on the DHCP in your router.,. so the router will give an ip to you pc
Posted on Mar 31, 2009
  • 597 Answers
SOURCE: Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Posted on Jun 01, 2009
WiFiNut
  • 53 Answers
SOURCE: where can i find the encription key on wua-1340
There is no way that you can view the encryption key. It negates the purpose of creating one. You will have a to create a new one unfortunately.
Posted on Jul 06, 2009
Need a driver for a wireless usb adapter d-link dwl-g122
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
http://download.cnet.com/d-link-airplus-g/3000-2112_4-84765.html
http://download.cnet.com/d-link-wua-1340/3000-2112_4-92021.html
hope it helps
Apr 16, 2012 | Computers & Internet
I lost the software cd for my dlink wireless adaptar i think it a wua dlink 1340
If you go to the link I have provided you can down load the driver
http://download.cnet.com/D-Link-WUA-1340-USB-Adapter/3000-2112_4-92021.html
Aug 28, 2011 | D-Link Computers & Internet
I have a 1340 and can not get the internet and the modem is worki
try to give a static ip address of router's ip range on the w/l network connection of the computer and then try to reconnect. Chk the driver version of the adaptor if old the try to download the latest version from the d-link website.
Still problem persists then finally try to change the w/l setting of the router.
thanx and regards
Sukhiii
Jul 24, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
Where can i find the encription key on wua-1340
Jul 06, 2009 | D-Link Computers & Internet
Can not connect to the internet thru a wireles D-link WUA 2340.
Hi Antonio, you need to make sure your routers wireless settings match the settings of the computers wireless adaptor. Both need to be exactly the same.
Jun 02, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
or
Mar 31, 2009 | D-Link Rangebooster G USB Adapter...
D-Link WUA-2340 RangeBooster G USB Adapter Installation Issue
http://support.dlink.com/products/view.asp?productid=WUA-2340
Mar 07, 2009 | D-Link Rangebooster G USB Adapter...
Westel 327W no longer accessing VPN
It sounds like your company has changed some settings for access into thier local intranet. Your IT guy will have to figure out what's wrong, becuase he would be the one with the knowledge of your companies settings. Perhaps they changed the shared-key, or something in the security settings.
Another note: If you have recently changed/upgraded any installations of firewalls or internet security software, check to make sure it's not blocking any of the IP address or ports you need open to access your company network.
Mar 28, 2008 | Westell Wirespeed VersaLink...
D-Link Rangebooster G USB Adapter (WUA2340) Logo
235 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
