Question about Garden
Husqvana 65 chain saw will rev fully when idle but dies when introduced to timber
  • Anonymous Mar 14, 2014
    chain saw won't idle very long
    Brigadier General:
  • 4,088 Answers
Sounds like the saw is running lean. Check the fuel filter, air cleaner and muffler for plugging. Check the condition of the fuel lines and that the fasteners on the carburetor are tight. If all ok, turn the 'L' and 'H' jet needles on the carburetor CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and the engine should start and run. Allow the engine to warm up, pull the throttle full on, and adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet will allow it to 'follow the throttle'. Set the idle speed screw til the chain stops moving, but keeps the engine running. Hope this helps!
Posted on May 14, 2010
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
I have a 450 husqvana chain saw trys to crank but only shoots blame out exhaust
if it is back firing means getting to much fuel try adjusting the air fuel ratio by turning the screws all the way in then 3 full turns out try it then adjust at half turns at a time until you get it right
Aug 08, 2014 | Garden
Husqvana 371k starts but stops when i put choke in and throttle on. why?
Is there fresh fuel in the tank? If the fuel has been there for over 2 months dump it out and put in fresh fuel and try starting again.
Jul 31, 2014 | Husqvarna Chain Saw Models 371, 372xp
How to check for proper chain tension husqvana 450e
You should be able to move the chain with your hands, but not too easily. Please wear gloves when doing this. Also, if you pull the chain away from the bar at the middle of the bar, there should be no more than 1/8" between the bar and chain.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Husqvarna 450 e-series 18" Chain Saw
Can i use any 2 stroke oil in my husqvana
Yes, as long as it is a good quality oil. Some manufacturers recommend less oil in the fuel if you use their brand of oil, but using a branded make will not be detrimental unless it is a cheap make. Just watch te amount of smoke coming from the exhaust, it should not be excessive but should also just be visible in the sunlight.
Apr 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chain keeps freezing up on me and its brand new. how do I fix tha t on my husqvana 16 inch
Turn the chain brake off, then remove the bar and chain. Clean the side of the engine where the bar fits to, start the engine and observe whether the small oil port on the engine oozes out oil. If nothing and the oil tank is filled, put the saw back together and take it back to the seller for warranty repair of the oil pumping system or a fresh saw in exchange. Hope this helps!
Dec 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine is probably starving for fuel. Check the filter inside the fuel tank on the end of the fuel pickup. Also check the pulse diaphragme for perforation. check the fuel for water too. Lastly, if all these are ok, try altering the main mixture screw to make the engine run a little more rich.
Mar 19, 2010 | Husqvarna Garden
Threads in barrel that hold exaust bolts have been stripped,husqvana 350 chainsaw,would be grateful for advice.
Take it to a local chainsaw seller/mechanic. They will put in a threaded insert (Heli-coil) for less than the price of the tools required for you to do it. Call local saw shops for an estimate. Should be $10±. HTH
Lou
Nov 09, 2009 | Husqvarna Chain Saw 20" Bar
Engine cuts out
You probably have a fuel line that is cracked or has a hole in it of some sort. You should be able to take off the top cover and inspect these lines. If this is the problem, replace with new line & should work just fine. Let me know how it goes.
Mar 05, 2009 | Husqvarna Chain Saw 20" Bar
Husqvana electric chainsaw
Hi.
maybe its not sharper enough to cut those things that u r trying to cut.
check the saw tooth and use the chainsaw sharpener if u don't know how to make ur chainsaw sharpener take a look on this link.
click here.
i will fix u but you should rate me deal??
Aug 18, 2008 | Electrical Supplies
Garden Logo
162 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
