Question about Sony SLV-D360P DVD Player/VCR
There's no power
Yesterday while playing a video, the player shut down. now, there's no power. is the electrical wire gone or what?
  • Anonymous Oct 15, 2008
    WHAT DOES THE FUSE LOOK LIKE
  • hobbyhut Dec 20, 2008
    the power light blinks, bbut won't come on
Inside the machine there is a small fuse that may have blown. You need to remove the cover and replace the fuse. This is an easy fix as I had the same issue with mine.
Posted on Jun 05, 2008
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
My radio will play perfectly on turner but when inserting dvd/cd the radio only plays sound from the four internal speaker and not from the sub
try using your blue/white wire instead of the blue wire to turn your amp on. The blue wire is power antenna remote turn on and shuts off when leaving tuner mode. The blue/white wire is amplifier remote turn on.
May 20, 2011 | Jensen VM9510 Car DVD Player
I have a problem with my sony play station I had this problem for months When I turned on the ps2 it shuts down itself,I can reset it and i start playing but then again it turns off itself,Sometimes i...
The PS2 shuts off automatically when acquiring heat, it might have been cutting off due to excessive heat or overheating. If the system does not power on, well the internal power supply unit might have gone busted and generally a hardware failure causing this issue.
Jun 14, 2010 | Sony PlayStation 2 Slimline Console
Power to reciever shuts down after 30 seconds of playing a CD
if it doesn't shut down playing the other inputs check the rails the laser rides on there may be dirt/hard grease stopping the sled. or the may be a power overload caused by a faulty cd player and you system is going into the protect...
Dec 10, 2009 | Audio Players & Recorders
Wii Remote Problems!!
This is factory default with the Nintendo Wii, Try simply removing the batteries when done, OR!, which I do, is hold my hand over the top of the WiiMote and then press the power button, this prevents the Wii from getting the remote's instruction to power down, the remote thinks the Wii got it and then shuts down. Good Luck!
Aug 16, 2009 | Nintendo Wii Console
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Player shutting down after 10 seconds
Shutting down completely like power is gone or just DVD stopping with power on? If completely shutting down the look in power supply and find bad capacitor and replace. If DVD stops with power then look at laser, clean or maybe damaged.
Sep 14, 2007 | Polaroid PDV-1002A Portable DVD Player
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
My Pioneer Player Makes A Beeping Noise When Playing Music Videos
why does my pioneer avh-p5700dvd power up but it starts a beeping noise and then it shuts down ?
Apr 05, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Sony SLV-D360P DVD Player/VCR Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
