Question about Water Heaters
I have a 80 gallon Ge smartwater hot water heater model # SE80T .can a burned out heating element in the water heater cause a circuit breaker to overheat? Thanks
    Scholar:
  • 102 Answers
I know an element can cause the breaker to trip. But I dont know about over heating. That sounds like a wiring issue. I would contact an electrician. Hope this helps.
Posted on May 14, 2010
Hot water recover time
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
Jan 04, 2014 | Camco Copper And Zinc Standard Hwd Water...
Install problems ge hybrid water heater
1) Copy following links for detailed resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
2) T2 is tank temperature sensor failure located just above upper element.
Call for service/ warranty.
Call GE 888-433-4394
3) Was water heater completely full of water before applying power.
Do you have 10 gauge wire and 30 amp breaker.
Is unit receiving 208-240 Volt power. Click breaker fully on-off.
Move wire to another same size circuit breaker.
Mar 03, 2013 | General Electric Ge Appliances GEH50DNSRSA...
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
9. Do a full troubleshoot on electric water heater
Dec 07, 2010 | General Electric GE SmartWater Household...
After putting in two new heating elements, my water is not getting hot. why is that?
Did you fill heater with water before appling power? If not elements may be burned open. Check circuit breaker.
Nov 28, 2010 | General Electric GE SmartWater Household...
How to replace heating element on a 20 gallon ge electric water heater
First thing is to cut power supply off at the breaker box. Next turn main water to the water heater off. Once power and water is cut of to the water heater you are now ready to drain the tank for element removal.
Once water is drained remove wires from element and remove with socket if it is that type of element or 4 bolt type.
Upon starting putting it all back together remember to open all faucet's hot side to purge out all air out of system before turning power back on.
Water need's to be running out of faucet's and no air before cutting power on. If you turn it on before air is out of system it will damage th enew element you just installed.
Aug 09, 2010 | General Electric GE SmartWater Household...
I have a 80 gallon Ge smartwater hot water heater model # SE80T .Can a burned out heating element in the water heater cause a circuit breaker to overheat? Thanks
Normally no, but for a circuit breaker to activate, there has to be excessive current draw somewhere. Is the circuit breaker exclusive to the water heater? If it is then the heating element may have shoirted internaly. Fit a new element and restest. Don't forget to check the condition of your sacrifical annode too.
Mar 19, 2010 | Water Heaters
My hot water will not get hot at all. Model SE40M12AA01 Stop getting hot over night. Breaker to heater was tripped, I reset it and still no hot water.
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Feb 21, 2010 | General Electric GE SmartWater Household...
Water not getting hot / Kenmore Economizer 6 / Electric
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
Mar 06, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
130 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
