Question about Casio DL 250LA Calculator
What size paper goes in Casio DL-220LA - Casio DL 250LA Calculator
Why do I keep getting an error message when I try to print on plain paper?
try to check your document paper size settings. if your document is in pdf format, try to unchecked the select paper size automatically but it will not respond since it is dependent on the paper size setting of the document.
Jul 17, 2014 | Ricoh Aficio SP C811DN-DL Printer
2-ply paper
The Casio HR-8TM only takes the 2 1/4 calculator paper.
Sep 29, 2013 | Casio HR8TM Calculator
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
What is the paper size for Casio CE-2350?
44mm paper rolls. The size is usually written as width x diameter, so something like 44x75 will be fine.
If anyone needs a Casio CE-2350 manual, c-tech collective have one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-2350_operators_and_programming_manual.html
Nov 10, 2010 | Casio Parts Cash Register PC Desktop
I have a Canon MP460 & cannot print DL envelopes from a .pdf as there is a grey band showing in preview:composite. Nothing prints in this band. How do I remove it?
This appears to be a bug with the Canon software. It is not using the correct dimensions for a DL envelope.
The solution is to use a Custom Paper Size. Make it 110mm wide and 220mm high (which are the correct dimensions for a DL envelope).
To make it easy to select this size in the future, set the Custom Paper Size (plus any other options you want) and then click on the Save button. When the save dialog appears, click on Options and make sure that "Save the paper size setting" is checked. Then enter a suitable name (e.g., "Envelope DL Custom") and click OK.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Casio qt-6600 Order receipts sizing
U mean the paper size? the QT-6600 is a rom based terminal, paper size is depend on the receipt printer u attached with.
If u mean the wording, u may change it in PGM2, by pressing the "DBL" key when u input the word.
May 07, 2009 | Casio Parts Cash Register PC Desktop
Error E
Kind of sounds like it. Make sure that there isn't a little piece of paper stuck in there where the paper feeds in. Have seen that happen before. If nothing else try pressing reset button on bottom or machine and see if that helps.
Nov 18, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Casio DL 250LA Calculator Logo
153 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
