Question about Acer AL2016WBbd Monitor
Monitor U sent me a solution on my monitor going black off and on. You suggested that I go to the catalyst contron center. I cant fing this on my computer. I have winows xp proffessional 64 system.
  • 3,037 Answers
Go here http://ati.de/products/catalystcontrolcenter/index.html
then click on Catalyst Control Center for Windows XP
select your system, etc.
Click GO
and download it, you should then be able to fix your problem, let me know if you need any further help
Posted on Mar 30, 2008
SOURCE:
I have a Dell Optiplex GX620 and Dell flat screen monitor model 1907fpt. The monitor is flipped upside down and all of the answers I can find say to use Ctrl + Alt + Arrow or Ctrl + Alt +R and this does...
I am trying to remember if that is a radeon display chipset - if I recall correctly it is, and should be using the catalyst drivers. If the drivers are up to date, this is the solution.
You want to open the radeon vision engine control center, go to common display tasks, then desktop rotation, and choose landscape (non-inverted).
if you are not running a radeon chipset, or are not running the ATI Catalyst driver set then post a comment here and I will help you further.
Jul 20, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
Screen goes black for 4-5 seconds then comes back on
Go into the Catalyst Control Center and check "reduce DVI frequency on high-res displays" and leave "Alternate DVI operational mode" checked. This should resolve it. It is because of your video card that this problem is occurring. Let me know if you need additional help or if this doesn't fix your problem. Good Luck.
Mar 29, 2008 | Acer AL2016 W 20" TFT LCD Monitor
I have Samsung BX2250. My problem is when i set up the resolution to 1920x1080, It didn't use up all the panel's screen there are black panels around the screen. My Graphic card is a ATI HD5870. how can i...
Had the same problem too... It's because it's set to underscan. To remove the black border, right click desktop and click Catalyst Control Center. Click the Graphics tab on the upper left portion of the Catalyst and choose desktop and displays. Right click the picture of the monitor at the lower part of the screen and choose Configure. At that screen, Click the 'Scaling Options' tab and move the slider all the way right to Overscan.
Triad'Warfare [url=http://valid.canardpc.com/show_oc.php?id=1571106][img]http://valid.canardpc.com/cache/banner/1571106.png[/img][/url]
Dec 26, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Can't setup dual monitors on ati radeon x1050
Hello
You might have installed ATI's CCC, "Catalyst Control Center", along with the display drivers. I suggest you download the latest combo-CCC and drivers for your video card. ATI comes out with new drivers pretty fast. When using dual monitors CCC is where you want to setup your monitors. After you set up the catalyst control center you'll find it much easyer to assign what monitor displays what. One other suggestion. ATI will want you to uninstall any other software for your ATI card even though all you have is ATI software.
Hope it helps, if so do rate the solution
Dec 21, 2010 | ATI Computers & Internet
I have my monitor plugged in with a hdmi cable to my ati radeon hd 5750 video car and everything has the latest drivers but I still haven't filled up the screen. There is a 1.25" black margin on the sides...
It's an under-scanning problem. The setting to correct this is in the Catalyst Control Center Advanced settings. Upper left is a drop-down menu 'Graphics', from there chose 'Desktops
Aug 05, 2010 | Dell ST2210 21" Monitor
Configuring Laptop for Flat TV S-Video Connection.
Greetings,
Connect the second monitor to the blue VGA port. Download catalyst control center from the below link and install it. Using catalyst control center, you can configure dual monitor. You may need to check 'force tv detection' setting in catalyst control center.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/9-3_xp32_dd_ccc_wdm_enu.exe
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 07, 2009 | Computers & Internet
Black screen
Plz Check and change or Replace
1)RAM
2)Monitor's VGA cable
3)Any other Cards such as (Graphic,Modem etc)
Because some time Ram's cant work and system still black screen when start the system.
If RAM is Good working plz check monitor's cable
the 3rd option is replace/remove the Cards some times any hardware device failure complete computer system is Down
If Problem is still there
Go to Computer sales and Service Center
DON'T APPLY OTHER EXPERTISE!
Dec 12, 2008 | Computers & Internet
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Color display issues with BenQ FP757 monitor
Go to menu and try Recall all.
Also possible that panel is defective.
Samir
Oct 01, 2007 | BenQ FP757 Monitor
Acer AL2016WBbd Monitor Logo
79 people viewed this question
Ekse
Alun Cox
