Computer shuts down with Flt. Sim 09
Have a Toshiba MX with XP version, have extended Ram to 2GB all programs run perfectly, except when running the Flt.Sim 09, after 5-10 Min the computer shuts down.
Always delete back up system, Skype, Google, etc. which might interfere.
Please advise what could cause the prompt shutdown.
Regards, Johannes
  • 32 Answers
Hmm. Does the screen flash blue before it shuts down? And does it shut down or restart?
Posted on Mar 31, 2008
My computer keeps on restarting without my wish
Hi Davis,
I assume you are running MS Windows, which version I don't know, because you never posted that info, but MS windows up until XP was notorious for the BSOD, or Blue Screen Of Death. Is this the case with you, or is it RSOD, Red Screen Of Death, XP and later window versions.?
This is not a hardware problem, but software related.
Windows, by it's very nature is a resource hungry OS, the more programs you have runnning the more resources it needs to run, this is apart from hidden programs running in background, also consuming resources.
The only cure with MS Windows (any bloomin' version), is to upgrade your hard drive and RAM, the bigger the drive the better, 1 TB drives cost little these days, and RAM is cheap as chips, if for example you have 2 gigs of RAM installed now, ramp it up to 8 -10gigs, if your current hard drive is 700Megs, then get an external usb hard drive of about the 1-3TB capacity.
Windows is the OS that with every upgrade, has and is becoming a resource hungry OS, with many failings in it's build and structure.
I hope this has answered your query.
Regards,
Peter
Feb 19, 2013 | Toshiba SATELLITE L300-147 LAPTOP LCD...
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
Not enough video memory to play a DVD?
Go to www.crucial.com download their Advisor program and run it on your machine
It will report how much memory you have on board
1gb is the bottom line for running XP, 2gb for Vista
Using XP and a DVD player it is a 2gb application
3gb if you are running Vista.
Some laptops allow you to limit how much Ram Windows can steal on start up
Apr 08, 2010 | Toshiba Satellite Pro U400-S1301 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Fifa 09 freezing not running fast
Geforce 7100 is a built in graphics card, so you may not be able to play this game at a high setting. Try lowering the game settings to see a improvement in speed.
Aug 08, 2009 | Buck FIFA 09 for Xbox 360
My toshiba L300 keeps freezing and shutting down
How many MB YOUR RAM/ may you have lowest of Ram 256MB/ or 512MB only.....that why freezing your laptop. make it upgrade your RAm ...now adays all programs are updated to new versions.. if you using os xp -- sp2 or sp3 or higher than.. atlest you have minimun of ram 1 or max. 2gb..if VISTA min. 1 max 2 or 3GB
also alot of viruses.spyware or all unwanted programs. programs can make slow of operating system....., check first your programs then hardware .. change it if nessesary.
May 26, 2009 | Toshiba Satellite Pro L300 Notebook
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
I own a Toshiba Satellite M110...The problem I'm having is I can't get the laptop to run on anything higher than 2gb of ram...Yet the booklet and numerous tech and information sites say that it can run...
if i will suggest i think u can try a diff ram most times rams that r not compatible with each other may not run on a system. so to veriyfy that yr new 2gb ram pair is working try to install them one after the other that is, insert the first 2gb ram boot yr system if ok, shut down remove it n insert the other 2gb if it ok then they should work since it has been tested by the manufacturers n is written in the manual..
NB most times especially china products they may write anything on the body of yr machine but u will see a diff thing working so i dont know
guess u find help
May 27, 2008 | Toshiba Computers & Internet
Windows XP shutdown
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Feb 22, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
