Question about Jandy Laars Lite 2 Pool Heater 250,000 BTU / Natural Gas
This is the third Temp Control Assy replaced in 8 yrs
This is the third Temp Control Assy (pt # R0011700) that has gone bad in eight years. Is it possible to find an alternative to this part ?
    Top Expert:
  • Jandy Master
  • 7,912 Answers
Check gas pressure if too low it will run hot and soot up clean out exchange of soot should be ok
Posted on May 25, 2016
How do i remove the shift cable from a pt cruiser gt5 speed
Chrysler PT Cruiser shifter cable bushing replacement ...
? 5:28
https://www.youtube.com/watch?v=akgIKm1pQLM
May 21, 2014 - Uploaded by MotorCity Mechanic
Chrysler PT Cruiser shifter cable bushing replacement ... Part 1/2: 1999-2003 Jeep Grand Cherokee 4.0 ...
PT Cruiser manual stick shift cable bushing tip - YouTube
? 3:18
www.youtube.com/watch?v=mU0sgQn-0qw
Jun 19, 2015 - Uploaded by Justin Shiffler
PT Cruiser manual stick shift cable bushing tip ... how hard was this to replace? my right bushing is gone and ...
Shifter cable broken for the third time - YouTube
? 1:06
www.youtube.com/watch?v=MiHSkqSrsLY
May 8, 2013 - Uploaded by CJ Turner
Shifter cable broken for the third time ... Chrysler PT CruiserBrake Light Switch Replacement, Shifter Stuck .
Oct 29, 2015 | Cars & Trucks
Laars Lite 2 Pool Heater max temperature too low
if hooked to a system increase temp if not try new temp sensor in heater
May 04, 2013 | Jandy Heater Temperature Control Assembly...
Why doesnt my 1988 98 oldsmobile shift into third gear
If it is a manule trans then you need to shift it sooner. And for the reason it will not go into third gear is the gear could be gone or the saycronizer is bad. You will have to put in a new trans or get this one fixed in order to get third gear.
Dec 10, 2012 | 1988 Oldsmobile Ninety Eight
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
Top half of freezer is not working, ice has melted and all food item's have thawed. the lowr half of the freezer seem's to be working and item's are frozen, this is a Hoptpoint side by side maybe 3 to 4...
Your freezer fan has stopped working . Usually , this is a main control board gone bad . This board controls the fan in the freezer and is located behind the refrig , behind an 8 X 10 " panel . Pt.# WR55X10942 .
Jun 13, 2010 | Hotpoint HSM25GFRSA
Frigidaire side by side
there could be a partial restriction in the capiliary line causing higher that normal high side pressure in the system when the compressor is running
have the tech to replace the suction line along with the compressor let them know that this is the third one gone bad
Apr 26, 2008 | Frigidaire FRS26R4A Side by Side...
Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
Jan 04, 2008 | Office Equipment & Supplies
Sony 20in TV/VCR combo suddenly stopped working?!
The problem you have with the tape is probably one of the nylon or plastic gears have worn or cracked and the mechanism has gone out of timing. the no channels is probably the tuner assy. These Ive seen go out a hundred times. Unfortunatly this is an 8 year old unit and the cost to repair will most likely exceed, or close to the cost of another unit, as I know that tuner assy part #TELH-005A cost around $63.00, and the cost to repair the deck assy depends on what the problem is and then add labor ,your looking at around 150 to 200 bucks. Good Luck
Jun 24, 2006 | Sony KV-20VM42 20 in. TV/VCR Combo
Jandy Laars Lite 2 Pool Heater 250,000 BTU / Natural Gas  Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
