Question about Maytag Atlantis MDE6400AY Electric Dryer
No heat in dryer and can't find reset button
Figured out how to get the front off the LG dryer and now can't find the reset button to reset it.
where is the dryer reset button?
  • 3 Answers
The reset is on the thermocouple between the two wires - make sure the unit is unplugged.
Posted on Jul 07, 2012
    President:
  • Maytag Master
  • 2,651 Answers
Lg is a little more tricky to get apart, but ther are a few screws infint of the lint filter housing, as well as afew under the main lid."pop" the top by inserting a screwdirver into the clips located on either side perhaps 3 inches in or so.and then trher are a few phillips head screws that willl release the front panel,along the bottom right side is a few thermostats as well as a heater asssy, one of the thermostats have a red button protruding from betwwen the 2 wires, try pushing it in.it will reset the thermostat(its gotten too hot and "popped" for safety reasons...CHECK YOUR VENTING
Posted on Mar 30, 2008
IS THERE A RESET BUTTON ON A MAYTAG SDE515DAYW
Their is no reset button. The fuse is mounted on the heating element. The heating element is mounted on the lower left rear of the cabinet. To access it you must remove the front panel. The fuse has 2 orange wires on it as seen in the video. I have the service manual also:
RS3200007R0 Amana Dryer pdf Google Drive
Apr 02, 2014 | Dryers
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
My LG gas dryer has had the thermostat sensors replaced and reset twice already, but after a few loads it stops producing heat. I have taken off the new exhaust outlet as I think the flapper may be...
You will need to disassemble the top panel, the control board, the front panel and the drum assembly to get access to the reset switch. LG has posted that once the button has tripped, it is recommended that it be replaced rather than constantly resetting the button.
Good luck.
Sep 28, 2010 | Dryers
Have a LG gas dryer dlg7188wm....doesn't heat
Take top off, then start unit. You can see orange glow in about 10 seconds on front bottom right by looking down from the top if the glow igniter is working.
Jul 27, 2017 | LG Dryers
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Mar 24, 2008 | LG DLE2532W Electric Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Unplug the dryer. Disconnect the vent hose from the wall and clear any lint etc. from the opening. Anything clogged with lint will continue to cause the heating element to "trip" for safety reasons.
Open the top by pressing in on the hidden metal clips on the right and left front (there is a small gap below the top section) Use a putty knife or screw driver to press in on the clips. Lift up like a car hood and then prop it up while you're working. Next open the dryer door. Remove the two screws on either side of the lower opening. Now lift the front up and out, set off to the left side as it is still connected by a wire. Look into the lower right side of the dryer with a flashlight. The reset button is located between the two wires that attach to the outside of the cylindrical drum at the 7 o'clock position. You need to be lying on the floor so you can reach your hand in. It is about halfway into the dryer. Press the button. Now reassemble the dryer before you start it up again. For a gas dryer - let it run and you should hear it "fire" up within a minute and the heating will begin.
Oct 10, 2007 | LG DLE2532W Electric Dryer
LG Gas Stacking Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
1,356 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
