Question about Vacuums
Water spray in the front of my bissell not working
  • 126 Answers
Check the belt on the pump. These should be changed once a year. It is also possible that the heater is plugged. This problem will require a technician to repair.
Be sure that there is shampoo solution in the small tank and if not, turn the adjustment knob to "off" or the machine will draw air into the system and the punp will get a vapor lock and not work.
Posted on Mar 30, 2008
SOURCE:
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 9500 won't spray water
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
