Question about Nikon Coolpix 7600 Digital Camera
Camera won't turn on, although batteries are fully charged and both show 1.2 V on a meter.Tried with a spare set of batteries and nothing happened either. Any clue how to solve this problem?
  • 4,889 Answers
Does the camera indicate that its on in any way? Like blinking battery light or stuff like that?
Posted on May 14, 2010
  • eagle338
    eagle338 May 15, 2010
    It looks like you have accepted it by mistake. I will see you through this though. Please send your correspondence to my e-mail vls_powerful2002@yahoo.co.in and I will respond ASAP/
Mark iii 5D will not turn on- battery is fully charged. I have tried taking the memory card out, battery out, lens off, etc and then replacing all of the above and restarting, but nothing happens.????...
And you are sure the fully charged battery also has enough capacity to power the camera? or it only reached a certain voltage so the charger says it is charged?
Also did check the contacts on the battery and in the camera?
Make sure the battery has enough power, by measuring the voltage with a multi meter. The voltage should be higher than what is printed on the battery.
Mar 15, 2015 | Cameras
Whats the most advisable type of battery for my ge a830 digicam?baterries i have tried seem to have enough power even for two shots..
Try Energizer Ultimate Lithium. If it still won't last for a long time, then there is definitely something wrong with your camera and you need to service it.
Nov 01, 2011 | GE A830 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
I have a Olympus FE 4000. I purchased it this past year and it worked fine for a while but all of a sudden my camera shut down. I though the battery simply needed charging so i charged it. when i put it...
Yes, it's possible. Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
The best way to proceed is to buy a new battery, then try to charge it. If it charges and the camera works, problem solved.
If it doesn't charge, then you will need a new charger. The battery will not be wasted though, as it is always handy to have a spare.
If having bought both new battery and new charger you camera still won't work, then you will have to look into your warranty or return it to the shop- however that works in your country.
It is possible to check the voltage of the battery with a meter (you can buy a general purpose multi-meter cheaply) but this takes a modicum of skill and interpretation. Even a run down battery may show some voltage on a meter, as it doesn't draw much current.
Nov 03, 2010 | Cameras
Turn ignition on,nothing happens,battery is fully charged.
How do you know battery is fully charged?? Do you have a load tester or at least a volt meter to test it?? Seriously, the battery may appear to be charged and show 12-13Volts on a meter, but fail when placed under load.
Check also the bolts on the battery terminals.... they may be loose.
Do you get any display on the dash? EWS error??
Aug 16, 2010 | 2008 BMW R 1200 GS Adventure
Camera will not extend the lens when turned on and cannot function although batteries are fully charged
Although I had tried two sets of batteries I purchased another and the proplem was solved................it was just the batteries!!
Mar 29, 2010 | Kodak EasyShare CX7430 Digital Camera
Camera lens does not retract
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 21, 2009 | Kodak CX6330 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
Canon IXUS 960IS
This happens when the battery try recharging them...
Oct 04, 2008 | Canon IXUS 960 IS Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Nikon Coolpix 7600 Digital Camera Logo
43 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
