Question about Microsoft Xbox 360 Controller
My controller is not working even with new batteries. What should I try next?
    Problem Solver:
  • 5 Answers
Check the terminals maybe bend them if they have been pushed in too far
Posted on May 18, 2010
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
My emerson remote will only work sometimes even with new batteries. i push any button nothing, then if i fumble with the batteries and mess with it for awhile it might work? i just need a phone number for...
Try fixing your remote controller.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part of the circuit board, with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 26, 2010 | Emerson Premier SR110 Remote Control
might be controller may have some hardware defect visit service center or else buy your self a new one.
Mar 19, 2010 | Microsoft Xbox 360 Controller
My friend brings his wireless 360 controller and when he turns it on the system and controller doesnt connect. why?
Are you syncing it? (Press and hold the small button next to the power on/off button on the Xbox 360. It's a tiny little round thing.) Also, you have to press and hold a similar button on the 360 controller, next to the RB button.
If you have tried this and it is still not working, try turning off the Xbox 360, and syncing his controller to the console first. (Meaning before you sign in, or even turn your controller on.) If this doesn't work either, I would suggest testing another controller. (Perhaps it is his controller that is faulty in some way.)
Hope this was of some help.
Jan 28, 2010 | Microsoft Xbox 360 Controller
Logitech Harmony 890 Pro - Blank LCD Screen
Replacement screens can be found on ebay for around $25-$30. I was having the same problem as everybody else, and none of the solutions posted online worked for me - software, firmware, battery pulls, safe mode, etc. I replaced the screen in about 5 minutes and was back up and running.... I almost bought a new remote, but figured I'd try the $26 screen first.... Glad I did..
Sep 29, 2009 | Logitech Harmony 890 LCD Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Samsung remote control
Remote control problem: your going to laugh at this but this was an easy fix, after my husband told me that there was something wrong with it, I tried to use the remote and he was right, it wasn't working. I changed the batteries that evening and sure enough it still wasn't working. The next day I had a closer look and thought that it wasn't right that a new t.v. remote wouldn't work, and lo and behold the problem? My housekeeper put a picture right in front of the electric eye of the t.v.! Guess what, it works quite fine again, thank-you for your time, and I am glad that it wasn't anything major. Peggy
Jul 22, 2008 | Samsung TV Remote Control
Xbox 360 controller will not turn on
If you're using the AA battery pack, try this.
Use a small screwdriver or other such tool to pry up the metal spring on the back of the battery pack as seen here:
This will give you access to the two small metal prongs underneath. Pry these up as well, as far as you can (see below).
Finally, push the metal spring back down just enough so that a little bump of it appears above the battery pack, like so.
Now power it up and test it out!
Mar 17, 2008 | Microsoft Xbox 360 Controller
I need help programing my logitech harmony 520 remote control.
try it on a different usb port, or even a different computer. try a different cable, and if all fails, remove the batteries on the remote, put them back, and try this all again.
Mar 23, 2007 | Logitech Harmony 520 LCD Remote Control
Microsoft Xbox 360 Controller Logo
97 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
