Question about Whirlpool MH7130XE Microwave Oven
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box they are ok. Is it an internal fuse? If so what part # do I need?
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: microwave MH7130XEB-2 stopped working while
There are 2 fuses in your unit.
The line fuse: (Item 14) (20 A)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260484&diagram_id=93994#d93994
and the Thermal Fuse (Item 5) same link
Either of the 2 can cause your unit to no longer operate. Most of the time the failure is the line fuse.
Thanks for using FixYa.
Kelly
Posted on Mar 19, 2010
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box, they are ok. Is it an internal fuse? If so what part # do I need?
Hello :
Problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service .
You could check for manual here :
Whirlpool MH7130XE Microwave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Whirlpool MH7130XE Microwave Oven
We were cooking a dish and stopped it at the mid point and to add some sauce and it would not restart. Clock and everything is out. Everything esle in house works, no circuit breakers were off. The Jenn...
The same thing happened to ours last night. We went to add another minute of cooking time and realized the oven was dead - no clock, no display of any kind, and no more cooking!
I've verified the power outlet is OK. Ideas???
Feb 19, 2010 | Jenn-Air M170 Microwave Oven
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LMV1630st sparked and then stopped working.
http://www.fixya.com/support/t886241-power_turns_off
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
Sep 01, 2008 | LG LMV1630ST Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
62 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
