Question about Acer AL1912 19" LCD Monitor
My monitor takes forever to load. It only started to happen recently no more then a week or 2. Every time I turn on the monitor the green light blinks several times. After it stops the monitor just keeps repeating the acer logo about 6 times maybe more. Don't know what to do.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
My monitor takes forever to load. It only started to happen recently, no more then a week or 2. Every time I turn on the monitor, the green light blinks several times. After it stops, the monitor just...
Most likely caused by defective capacitors in the power supply. This is quite a common problem.
If you have some electronics skills, you may be able to change them yourself - look for bloated, otherwise deformed or leaking capacitors, typically in the 470u - 1000u / 25V range. Replace them with 105°C rated low ESR types of the same value and voltage rating.
If you don't know what I am talking about, bring it in for repair (if it's still worth it...).
Mar 19, 2010 | Acer AL1912 19" LCD Monitor
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
Monitor won't turn on
in the output section of smps some condensors are faulty
Dec 12, 2009 | Computers & Internet
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
Black screen blinking green light
You have a bad backlight fluorescent bulb.
Dec 28, 2008 | KDS 17S 17" Monitor
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Acer AL1912 19" LCD Monitor Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
