Question about Refrigerators
Age of ge model TBX21J refrigerator Top freezer with ice maker 20.7 cu
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
  • 152 Answers
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Posted on Feb 28, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
GE 18.0 Cu. Ft. CleanSteel Top-Freezer Refrigerator - GTL18JCPWRBS Water isn't going to the ice maker even though the water supply is on
Locate and replace the water filter. It should be covered in the owners manual. If that is not the problem, then the solenoid that turns on the water supply is shot, at which point you are probably better off just buying a replacement ice maker.
Oct 02, 2013 | GE GTL17JBSBS 28" 16.6 Cu. Ft. Top-Freezer...
I need to disconnect my ice maker from my GE TBX18DI refridgerator has anyone done this?
You should be able to reach behind the ice maker and unplug it from the wall.
Nov 27, 2012 | GE J Series 18.2 cu. ft. Top Freezer...
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
I have a broken in freezer Ice maker in a GE profile fridge and freezer how do you change it
The ice maker usually hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Apr 06, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker just quit working for no apparent reason
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
vzCgser
Nov 05, 2009 | GE Profile 24.7 cu. ft. Top Freezer...
Ice maker stop working
heatman101
iuiuiu
Dec 10, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
Top freezer ice maker not putting out ice
We shut down the freezer for 12 hours and the ice melted in the pipe. Thanks
Jun 21, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
