Question about CTX S761 17" LCD Monitor
When I boot my system, it tells me the setting is
When I boot my system it tells me the setting is out of range - 1024 by 768. Also when I get into linux I am unable to select this resolution
  • 11,361 Answers
The native resolution for this mnoitor is 1280 x 1024 @60 Hz. It is either you do not have the correct driver installed for yor video card or your mnoitor has the problem inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
2 Suggested Answers
  • 34 Answers
SOURCE: When I boot my system, it tells me the setting is
update ur bios
Posted on Mar 19, 2010
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Parameter out of normal operating range, computer will not boot up
Probably need to replace the hard drive and reinstall your operating system. Can you boot from a cd? Do a hard drive test and post the results.
Feb 24, 2014 | Microsoft Windows Vista Home Premium with...
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
I have sony vgc-ra-834g, computer working in past no problem, i turn computer on in boots up and stops and montor indicates that is out of range, anyone?
It means your system display card settings are too high for your monitor. Boot your system into safe mode and set the display settings lower. When you boot your computer, before it shows the windows loading logo press F8 to get into safe mode. When windows loads right click on your desktop and choose properties. depending on what operating system you have, after poking around you should find a setting measured in hz, in a drop down menu, and lower it (60 hz is usually the default for most monitors.)
Mar 03, 2011 | Sony VAIO VGC-RA834G (27242667839) PC...
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
Monitor says: "Out of range"
This means that a video signal has been detected but it is beyond the range for display. As an example, if the monitor can only display 1024x768 and you send it a signal at 1280x1024, you will get that message. Try to downsize the display settings on your computer system until the monotor works.
Dan
Nov 06, 2009 | BenQ FP767 17" LCD Monitor
I have a Gem gl-190z2 monitor that displays over range after boot
Just lower the screen resolution
Boot into safe mode first by repeatedly pressing F8 and select safe mode
once booted click on an empty area of the screen and take it from there. 800x600 is a good starting point
Re-boot and adust as needed.
Your monitor was just telling you it was too much for it to handle thats all.
Sep 22, 2009 | Systemax Scanport Gem GL-190Z2 (Black) 19...
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
PC NOT BOOTING
When it goes in to your BIOS, its telling you something is wrong. Check your settings or change to it default. Set you first bootable device to the CD/DVD. Insert your bootable Win CD and then save settings and "exit". Your system will then boot to the CD. It'll prompt you as to what you do next. Do Not use the first "repair" option. Go to the next screen and follow instructions. Hope this solves your problem.
Sep 15, 2007 | Microsoft Windows XP Professional With...
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
See all CTX S761 17" LCD Monitor Questions
CTX S761 17" LCD Monitor Logo
64 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
