Question about Philips CDR795 2-Disc CD Recorder
Philips CDR 795 Power Supply Problem
I get erratic operation that I've seen before. I was told it needed a new power supply. I sent the unit in when it was under warranty and it was fixed but now the problem is back. I'm getting the same symptoms as before. Trays may or may not respond to open buttons and other erratic operation. Does anyone know what it is on the power supply that goes. Capcitors and voltage regulators I know often cause problems in power supplys. I'm not using it anymore but I was thinking of fixing it if it's not too much of a problem and then auctioning it off on ebay. I may go ahead and test the caps. It has been a few years since I've worked with electronics.
  • Philips Master
  • 5,568 Answers
I don't know what you are using to check the caps but in order to find the culprits, it's almost mandatory to have an instrument that will measure both capacitance and dissipation factor (DF) since that is what is killing most of our modern electronics.
If you don't find any caps pregnant or leaking deposits and plan on shotgunning it, I'd start with those with values between 4.7 & 100uFd as these are the most common failures and mostly in feedback paths and are lower voltages.
You can buy them at Mouser Electronics with no minimum charge and 'at cost' shipping.
Good luck-
Posted on Jan 13, 2009
I need a new power supply unit for philips dvd hts3569/98 home theatre system that got burnt
WOW! Your power supply is exotic!... You MAY have better luck searching for similar supply models shown below? They all (apparently) all use the same supply. Methinks chances of finding a used one are quite slim.
I WAS able to locate a SERVICE MANUAL for:
Home Theater DVD Player HTS3510/12/51/55/78/93/94/98
PAGE 7-1
shows a FULL POWER SUPPLY SCHEMATIC WITH voltages and part numbers ~ YES!
Know there are FIVE different voltages provided FROM the supply... which ONE or ONES are missing?
The TROUBLE SHOOTING CHART is very well written and should help you greatly!
Most of the parts appear to be 'standard parts' except for the 2 transformers!
From memory, T501 and T502?? Don't quote me on that.
Trouble Shooting Chart.......................................................5-1
Anthony
http://diagramasde.com/diagramas/otros2/PHILIPS-HTS3510.pdf
Dec 14, 2017 | Philips Computers & Internet
Does a solid green light mean the power supply is ok when disconnected from motherboard and drives, ATX-300-12Z
Not necessarily. The green light usually just signifies power to the power supply. Amazon sells a cheap power supply tester that can verify everything on a power supply from old to new.
Jul 21, 2014 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Power surge knoked out pic.
Get the set diagnosed before shelling out money for a new power supply. I've seen many cases where a power surge takes out multiple boards.
Oct 28, 2012 | Sanyo Televison & Video
I need Power Supply unit ATX-300-12Z CDR for my H Pavilion desktop. P/S HP P/N 51882625
You dont have to replace it with the exact one...just shop around and find a 300 watt ATX power supply. You can find a few good deals around the internet. (tigerdirect.com...newegg.com....etc)
Jul 30, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I HAVE A PROBLEM WHIT CONNECTION OF PHILIPS "POWER
Hi.
Send me Your e-mail address.I can send scan of operating instructions.
My adress: slaweksci@op.pl
Best Regards
Nov 06, 2010 | Philips POWER SUPPLY (41644158) Power...
Brand new router works sometimes
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Power supply
Usually this will damage the power supply only. To make sure your that your motherboard is working, try to find a working power supply unit and connect it. If it does not work your motherboard may be get damaged. Also check for warranty. If your system contains a graphics card, check that too, it may also get damaged with voltage variations.
Oct 02, 2007 | ASUS P5LD2 Motherboard
Philips cdr 765
I just purchased one from Ebay. It plays fine on both sides. The recorder will recognize CDR's and the display will say recordable media. But, when I attempt to actually record, it won't work. I have another unit exactly like this one and the CD's I have work fine with that unit. I'm guessing this unit's recorder is bad? Any suggestions? Thanks.
Nov 06, 2006 | Philips CDR765 2-Disc CD Recorder
Philips CDR795 2-Disc CD Recorder Logo
146 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
