My cd/dvd drive does not work - previously working fine - could be after trying to copy a dvd a couple of weeks ago. any ways i can prevent reformatting hard drive and reloading xp again. everything else works fine.
    Genius:
  • 1,019 Answers
you should,nt have to re-format or setup xp again.
1:) check the computer for viruses. viruses-trojans et,c malicious software can lock off drives.
2:) go into start/control panel/system/device manager.
click on cd/dvd drive if it,s there, uninstall it. restart the computer, you should then get a message new hardware found.
install drivers as necessary.
3:) check the drives cables. the 4 pin molex connecter ( plastic block ) with 1 red 1 yellow 2 blacks, to ensure it,s connected correctly. or try an alternative one if available.
Also check the 40-80 pin ide cable.
4:) try a secondary cable ( 40 pin ) on the secondary connector from the motherboard ( if not in use ) set drive as a master.
Hope this helps.
Mike @ compurepair.
Posted on Mar 29, 2008
SOURCE:
What's your problem? CD/DVD burn in windows 7
just take to a shop and get the dvd drive replaced its only a 5 min job and the part costs about $30 its only a matter of taking battery out removing 1 screw and the new 1 just clips in
Nov 28, 2011 | Computers & Internet
Sony dvd dru-190a not able to read dvd's but reading cd's. Please help.
It sounds like the laser on your drive is gone. But there are a couple of things you can try first before buying a new one.
Uninstall the driver for it in Device Manager and let windows reinstall it automatically on reboot.
or use DriverEasy to install it > download here .
Uninstall and reinstall whatever burning software you use.
Take a look at this thread. Some of the tips there might apply to you.
http://www.techsupportforum.com/micr...ng-cd-rom.html
The drive I had trouble with back when I posted in July finally died a couple of weeks ago. CD's worked fine, just like you. All my good settings with Auto Run, etc, were still there. So I bought a new drive and I'm back in business.
Jun 11, 2011 | Sony 20x Dvd Rw +And -Dru-190a Burner
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
My NEC DVD +RW (NB3530A) has suddenly stopped recording. It recognises data on previously burnt discs but under 'properties' it simply shows any blank disc as full. It comes up with "incorrect device" when...
I have one that was refurbed and put in a Dell C series module, Hasn't let me down, so it's bad news I guess, maybe unable to fix, I paid $70USD for mine
Oct 05, 2009 | Computers & Internet
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
Hp pavillion dv1000 cd rom drive
memphisrains -
Sounds as though you may need to reinstall the driver for the laptop's cdrom drive. The easiest way I've found to do this is to download it directly from the manufacturer's web site; In your case, look here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-31831-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Download the file to your desktop (file name is sp30367.exe), and run the installation to reinstall & update the DVD/CD-ROM drivers.
Hope this helps!
-thinstatic
Jun 10, 2008 | HP Pavilion dv1000 Notebook
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Open Questions:
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
