Question about Sony DVP-NS575P DVD Player
"no disc" message
I tried to play a cd from the public library.The "no disc" message appeared.I removed the cd and found a sticker on it.I removed the sticker and reinserted it and got the same message.I tried 5 other cds and got the no disc message each time.
  • Anonymous Jul 05, 2008
    I have aproblem with sony player DVP-NS575P. It says No Disc when CD/DVD is inserted or not. When I put my hand on centeral IC it going to be hotter and hotter. At intial time the disc will move but latter no move. Please send me the possible solution.
  • 107 Answers
You should be cautious of what you do. every time you put a cd/dvd make sure your disc is clean, no scratches, no damage, no dirt, and no STICKERS sticking at the disc.
well if the problem just occurred inside your cd/dvd player, all you can do is to clean the optical eye with cloth and water and rub it at the eye(don't put to much water, just soak the cloth a little bit and don't put too much pressure against the optical eye)
if does it again adjusting the sensitivity of the optical eye would help, if still, you have to order a new optical eye though or buy a new cd/dvd player.
just be carefull of what you put inside your thing.ok?
have a good day and take care.
Posted on May 10, 2008
SOURCE:
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Feb 03, 2010 | Panasonic DVD-S25
When I try to play a disc, the message
Hi there! Depending on when last the CD Player was serviced, I would think that the laser is at fault and needs replacement. However it may also be a mechanical fault. The only way to know for sure is to take the cover off and to see whether the disc turns at least a little bit before moving to the next. Also check whether the disc lifts into position properly and moves freely. If all the above proves OK, then the laser is probably at fault. Remember that there is current running through the unit so please stay away from any wires and boards when checking this. Best Wishes and Good Luck. JUS004
Aug 21, 2009 | Technics SL-MC400 110-Disc CD Changer
Chevy Malibu 2004, CD disc is stuck in the player. When ejecting only get a clicking. The CD is from the library and has a sticker in the center. I have tried eject and pushing on the cd with a paper clip....
its jammed in the carrier obviously so yes by all means take out the unit remove the cover & disc that way you can check unit for any damge!
Cheers Rob.
Jul 20, 2009 | 2004 Chevrolet Malibu
CD/dvd drive disappear/will not play
Go to Control Panel and uninstall the program you installed (CD/DVD) installer. Reinstall the program.
Jun 20, 2009 | Microsoft Windows Vista Ultimate Edition
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
May 21, 2009 | Kenwood KDC-C669 6-Disc CD Changer
Sony DVP-NS575P DVD Player Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
