Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Magnavox plasma tv model 42mf230A/37
I have a black screen on my tv but it the green light turns on when i plug it in. I have asked around and everyone wants like $600.00 to fix so I started talking to more people and they think it is the motherboard, what do you think and where can I get a motherboard for that?
Same Problem
Apr 28, 2009
-   can i use my 37" magnavox tv as a boat anchor -
magnavx suks Apr 05, 2009
-   My magnavox plasma failed last week. It has a black strip along the y axis where the picture is not displayed. The rest of the screen displays fine. Was wondering if I cound replace a board to fix the problem? -
mrcyclist Mar 27, 2009
-   audio no video -   Guest Nov 10, 2008
-   I have the exactly the same TV and it is a black screen now with sound. Oh my gosh, this just happened too.
Linda 209-529-9050 ext. 118.-   Guest Oct 16, 2008
jtodd2120@sc.rr.com
I perchased a 42" Magnavox plasma TV on 9/3/06. I now have a blank screen with sound . Model # 42mf230a
I talked to the service representative at Phillips who owns Magnavox and was told there is nothing they can do. -
jtodd2120
Best Solution
posted on Aug 21, 2008
Rank: Apprentice
Rating: 98%, 3 votes
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Was this helpful?1 person thought this was helpful
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
how to unlock sansui channels
Hairline split in picture from top to bottom.Most noticable on blue screen before picture.
52" 7 yr old Panasonic, projection screen has lue and red waves of color and double pictures. ...
(More)
52" 7 yr old Panasonic, projection screen has lue and red waves of color and double pictures. What is it?
I need the remote control codes for the ilo television
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 30, 2008
Can I buy a new boeard anywhere
Comment by twayneaz, posted on Jul 19, 2008
My neighborhood bar has 8 of these screens, in about 2 years 3 of them have failed (turns on but no picture). 2 of them were catastophic failures, with evidence of a small fire having taken place on the high voltage row driver circuit boards and the flexible conductor going to the glass screen.
These are total losses as it will be too expensive to replace the glass (if I could even get it) and all the damaged pcbs.
The most recent failure happened 2 days ago, and it's still taken apart on my bench. Its failure is in a similar spot, although not nearly as bad, but still caused damage to the row driver pcb and damaged the power supply board upstream of it.
This one may be fixable since I may be able to salvage parts from the other 2. Unfortunately I am suspecting these failures may be caused by a short in the array on the glass plasma screen itself. This causes major current to flow through these circuit boards, they get real hot and ultimately the driver IC will delaminate from its heatsink and then it lets its smoke out.
I wouldn't recommend attempting repair on these plasma sets unless you really know what you are doing as there are high voltages present. (Va=70v, Vsc=-190v, Vs=200v, Ve=84v, Vset=195v) Between Vs and Vsc is nearly 400v of potential, that would hurt bad if you got into it.
But if you want to see if yours failed in this way: With the back cover off (make sure its unplugged too), look along the left side of the screen where the 6 flexible conductors come from the glass screen. These conductors are connected to 2 circuit boards. These circuit boards each have 6 driver chips with heatsinks glued to the top of them. Inspect the glue around the chips looking for discoloration. Mine went from pale white/yellow to a brown color where the failures were. Also check to see if any of the heatsinks are loose (you shouldn't be able to twist the heatsinks at all) as that will be evidence of excessive heat or a blown up driver. There is an audio board covering 2 or 3 of the drivers so you may have to remove the 2 screws holding it in place and some aluminum tape to really see all of the driver ICs. If you find problems in this area, the set might not be worth fixing.
After seeing how badly these things failed, I won't ever own a plasma tv, just to much risk of having an unrepairable boat anchor after the warranty expires.
Ted
Comment by bryanwilliam, posted on Jun 28, 2008
I plug the TV in the little red light cones on push power button and the green light comes on but no picture no sound what do i do
Comment by Papabear0405, posted on Jun 08, 2008
I was watching tv when the tv went black I could hear the sound but no picture. Please tell me its no big thing and that it's not going to cost that much to repair.
Comment by Guest, posted on May 16, 2008
I have the same problem one day my tv just would not turn on but the power turns on I get no sound or picture. I tried to unplug and plug back in and check the cable source and called magnavox and they did not help
